Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 12-31-2013, 11:10 AM   #1
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Random misfire?
Getting a CEL with random misfire and misfire on cylinder 2 and 6. My SA suggested I swap coilpacks with 1 and 4 and see if that changes the misfire. And a friend suggested it could be the knock sensor plug/wire from when I had a cat replaced a few weeks back. I cleared the code once two weeks ago and it came back today with another random misfire code. Anyone else got any other ideas or has this happened to you in cold weather? It's not running weird and I don't hear anything strange. No loss of power or any other indications of a problem. Btw this is on an LLT.
Thanks y'all!
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 12-31-2013, 11:38 AM   #2
MichaelH
SOCAL HT5
MichaelH's Avatar
Drives: 2013 BRM ZL1 M6
Try the coil packs and spark plugs and see if it helps, if that doesn't help it go away than try getting fuel system and injector cleaner hooked up to your fuel lines to see if maybe it's just gunked up. If that doesn't work than you may have to open her up and check your timing chains. Thing that worried me is that you have two cylinders doing it and not just one. Usually one means spark plug and coil
2013 ZL1 M6 - Mods-in the works
Old vehicles
2010 CGM Camaro (sold)
Other Vehicles:
2008 Kawasaki ZX6R-115 RWHP in mid summer
2006 Chevy Trailblazer SS- For Sale; Lots of extras
MichaelH is offline   Reply With Quote
Old 12-31-2013, 11:40 AM   #3
MichaelH
SOCAL HT5
MichaelH's Avatar
This just happened to a customer that brought his cts into service. Was only cylinder 4 and we changed his spark plug and coil and was good as new.
Old vehicles
Other Vehicles:
Old 12-31-2013, 11:51 AM   #4
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
mentioned this on the V6 LLT forum aswell but run dry gas and injector cleaner through it before anything else took mine 3 days to clear same two cylinder misfires like the other guy said gunked up probably because of the moisture from the fuel blend change. BTW Ethanol sucks so much in our cars for this.
Old 12-31-2013, 11:59 AM   #5
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
If you have a ported intake manifold, make sure the filler is in one piece and not inside the runners.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 12-31-2013, 12:40 PM   #6
BowtieBelle
Alright I grabbed some of this. Will run it through and see if the code comes back since we cleared it. If the code comes back will swap coilpacks and check knock sensor plug/bolt. Name:  ImageUploadedByTapatalk1388515237.682605.jpg
Old 12-31-2013, 12:43 PM   #7
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Good luck! Keep us informed.
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 12-31-2013, 12:43 PM   #8
BowtieBelle
When the light came back on today it didn't show 2 and 6. Just random misfire.
Old 12-31-2013, 12:50 PM   #9
BowtieBelle
I'm really thinking the gunk and moisture from fuel is a possibility. The car has 90k miles on it and I've only run seafoam through it twice and it was a long time ago. Gotta start maintaining now that she's aging.
Old 12-31-2013, 12:54 PM   #10
snymat68
snymat68's Avatar
Performance Mods
Aesthetic Mods
Old 12-31-2013, 01:02 PM   #11
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I have had the same thing happen to me, I have 60,000 miles on mine. With some research, I found out that my K& N CAI, was fouling my MAF sensor. This was then causing this CEL. I got some MAF cleaner and sprayed my sensor and it has taken care of it. Because the air filter has oil on it, the oil gets on the sensor causing the fouling. Performance hasn't been effected, just that annoy CEL.
http://youtu.be/aJLNQcFosSo
=Stephens= is offline   Reply With Quote
Old 12-31-2013, 01:07 PM   #12
BowtieBelle
I may spray the MAF with cleaner too. I have noticed a reduction in my gas mileage lately too; more than the usual drop with winter fuel blend.
Old 12-31-2013, 01:23 PM   #13
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
That is probably your foot hammering the gas because it's so much fun to drive fast. That seems to be my problem lately.
Old 12-31-2013, 01:47 PM   #14
snymat68
snymat68's Avatar
^ This
Performance Mods
Aesthetic Mods
