11-16-2019, 03:01 PM | #1 |
Drives: 2018 Chevrolet Camaro LS Join Date: Jan 2019
Small spot spot or oil on engine
I was putting windshield wiper fluid in my car and saw this on the engine.
What do u think? |
11-16-2019, 06:48 PM | #2 |
Drives: Sold Join Date: Sep 2016
I had same issue on my 2016, dealer said it is "NORMAL"
My engine getting more and more oil seep then finally they replaced gasket under the warranty but it happened again! Mine looks worst than yours now but my warranty is over. Last edited by camex; 11-16-2019 at 11:07 PM. |
11-16-2019, 07:37 PM | #3 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
It's not normal, it just happens to all of these engines. Spray it with some some engine cleaner from time to time.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
11-16-2019, 07:59 PM | #4 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
It's totally normal it's oil seep it doesn't just happen to these engines it happens to tons of engines that run perfectly fine for hundreds of thousands of miles. My 3.6 LLT Camaro had it as well and that thing was 4 yrs. old with 185k on it when I traded it in worse thing that ever happened was I replaced the alternator 2 weeks before I traded it in. The issue is it looks fugly and much worse then it really is.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
11-16-2019, 09:38 PM | #5 |
Thanks guys. I found the thread this was discussed in. The pics show oil deep at the exact same spot
https://www.camaro6.com/forums/showthread.php?t=547396 |
