11-26-2017, 06:05 PM | #85 |
Ended up putting mine back in. Definitely prefer it with the foam back in. You hear less resonance in the cabin while also getting more exhaust noise.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
11-28-2017, 12:53 PM | #86 |
Drives: Sold it Join Date: Nov 2017
Seems like everyone likes it at first with the foam out but
later decides to put it back in. One person reported a foam stopper depth of 1 3/4 inch One person reported a foam stopper depth of 1 1/8 inch Clearly the depth of these foam stoppers vary in depth. I am surprised no one is playing around with different foam stopper depths to see if they can tune the sound.. |
11-28-2017, 01:01 PM | #87 | |
Still have mine out. Mine was bunched up and kept that shape after I took it out. I had to use a 5" hemostat to get it out, so I think it was at least 3" deep. When 4 Cylinder mode kicks in it does sound bad... |
11-28-2017, 03:59 PM | #88 |
Drives: Hyper blue 1ss convertible 6 sp Join Date: May 2017
M6 SS convertible here! I like it you don't hear any thing till around 4500 with the pedal down, when your making power you can now hear it! My foam insert was two inches approximate
11-28-2017, 04:17 PM | #89 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
anyone know if the foam is also in there to keep unwanted air from entering the system AFTER the maf sensor?
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
11-28-2017, 04:28 PM | #90 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
11-28-2017, 08:33 PM | #91 |
I have an A8 so I know I'll hear the dreadful noise when it drops into V4 mode. But I also know my exhaust is way quieter than other 2LTs I have driven. I haven't taken mine out yet but I will probably cut the depth as opposed to yanking it out completely.
So the depth range is now 1 1/8" all the way up to 3" !! It also looks like some people have solid looking cylinder shaped piece of foam while others look like they have a folded up sheet of foam that was just shoved in there. |
01-27-2018, 05:29 PM | #92 |
Drives: 2016 Camaro V6 2LT RS Fully Loaded Join Date: Sep 2015
Does the V6 have this? Because I can’t find that specific tube..thought we had it as well. Thanks.
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15 My 2LT Review/Pictures/Mustang Comparison My 2016 Camaro Bose Subwoofer Install 2016 Camaro V6 Stock to Borla Atak Exhaust Sound 2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak |
01-27-2018, 06:59 PM | #93 |
Yes the V6 has a sound tube for sure. I have the V6 and took the foam out.
I, like some others, will be putting it back in. When the foam is out, I hear too much suffering/moaning kind of noise when the car is driven lean to conserve gas. |
01-27-2018, 08:45 PM | #94 |
Where’s it at in V6 any pic or vid?
Assuming you guys don’t have any exhaust work done? I can def see V4 causing it to sound like trash, but with it disabled and having exhaust work done it shouldn’t sound that bad?...
01-28-2018, 06:36 AM | #95 | |
Drives: 2016 Camaro Convertible 2SS Join Date: Jan 2016
"I did get rid of that "pffff" sound I could hear at low rpm". I had ordered a Range AFM Delete device in hopes of eliminating the pfff sound. I also bought a switch to go along with it so when driving highway I can switch it off and utilize AFM. So, if after removing the foam, the drone is too much at highway travel, I can switch the AFM back on and lessen the noise others are reporting. I will remove the foam, and install the Range device, when I dig the car out in the spring and try it out... very exciting news since all other mods cost hundreds of $.
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85 |
01-29-2018, 05:45 AM | #96 | |
Drives: 2018 Camaro SS 1LE \ 2006 Z06 Join Date: Sep 2017
https://youtu.be/HvnNKwFtzgI
2006 Corvette Z06 Fully built 824hp ProCharged. (ANGRY Z on YouTube)
2018 Camaro 1LE, ported/polished TB, AFe TB spacer, drop-in K&N air filter, deleted 2nd cats, GMPP strut tower brace, Mishimoto oil catch can, air box mod. LINEITUPRACING on FaceBook |
01-29-2018, 10:33 PM | #97 |
Did this "mod" today. Made a slight difference, but nothing crazy to me. I do have fuse #51 pulled, 2nd cats deleted, and K&N drop-in filter with cut stock airbox.
02-01-2018, 03:51 AM | #98 |
What is "cut stock airbox"?
