Old 11-15-2020, 12:48 AM   #113
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Originally Posted by TrackClub View Post
GMG did ya see my post #102?
Rears only take 30% (approx) of the load, so should last much longer, but worth at least checking anyway as part of the annual maint given the pads.
You bet, not sure if I’m going to do the job myself or not, but I have my father to help out and he’s worked on cars a lot more than I have
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 11-15-2020, 12:50 AM   #114
GunMetalGrey
Originally Posted by RUQWIKR View Post
I think the PN is actually 19207043. Buddy (Geoff) pointed it out to me. The pic they have for the other PN is for the vented ones, too. I will try to go correct my post. Sorry about that. Should not be an issue with returns at least for Amazon.
Updated: dug through my stash: opened the box to confirm: pic is right side up on my phone, but you can see the vented pistons and pressure seals in the sealed container.
Ordered the right ones from CarID, since Summit Racing is apparently out of stock until December.
Was able to cancel the order with Amazon without problem
Old 11-15-2020, 12:49 PM   #115
TrackClub
TrackClub's Avatar
Great stuff! Could be a nice family bonding project
Old 11-15-2020, 01:43 PM   #116
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
Will be cool to see more data on temperature drops with vented pistons
JT Camaro is offline   Reply With Quote
Old 11-19-2020, 08:08 AM   #117
slimjim2525
Drives: 2019 Camaro 2SS
Silly question. Just ordered titanium shims. Do these replace the plate on the back of the pad, or are they additional to the backing plate?
2019 Camaro 2SS, Shadow Grey
slimjim2525 is offline   Reply With Quote
Old 11-19-2020, 10:34 AM   #118
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
Additional. You just slip them right in behind your pads.
Best Regards,
Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake
SCCAForums is offline   Reply With Quote
Old 11-21-2020, 11:30 AM   #119
weemus
Drives: 2017 1SS 1LE
GM did performance testing (which I will try to locate) which claimed a -30C (-86F) temp drop with vented pistons.
weemus is offline   Reply With Quote
Old 11-21-2020, 11:53 AM   #120
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
that's impressive!
Old 11-23-2020, 01:53 PM   #121
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Yeah if that is true, it's very impressive and worthwhile.
Old 11-23-2020, 01:56 PM   #122
TrackClub
TrackClub's Avatar
Somebody has actually posted an actual test on his and recorded 75F (i think?) So close enough.
Old 11-23-2020, 02:07 PM   #123
TheRealJA105
Drives: 2013 C6Z06
I haven't seen any of this data, but I'm very interested now. Even 75°F is a huge difference!
Old 11-23-2020, 02:19 PM   #124
TrackClub
TrackClub's Avatar
Agree. And obviously individual tests will vary based on circumstances involved.
Old 11-24-2020, 11:43 AM   #125
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
I had CCB fronts on for a while early last year with and without vented pistons in the ZL1 1LE calipers. Without vented pistons cooked the outer dust seals within a couple of track days. I put stock J57 vented pistons in, and, before I took the CCB fronts off, I ran a few more track days without cooking the dust seals.
I took the CCB fronts off due to my young sons running a lot then, so, I put steel ZL1 rotors back on with stock pads.
RUQWIKR is offline   Reply With Quote
Old 11-24-2020, 12:12 PM   #126
SCCAForums
SCCAForums's Avatar
I have since installed the TItanium shims, and the SS 1LE (larger) brake deflectors, and had zero brake issues at ButtonWillow a couple weeks back. I was only out for 10 - 12 minutes, so shorter sessions, but was pleased with how everything worked.
The SS 1LE brake deflectors will scrape if running 18" wheels, and even if 19" wheels, probably not street friendly, mainly for track.
Best regards,
Dave
