Old 11-02-2020, 08:41 PM   #1
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Cooling Impact of Custom Brake Ducting
I’d like some feedback from ppl on what level of cooling impact that custom brake cooling air ducts (that direct air directly onto the rotor at all times) will have in terms of improvement over the stock brake cooling.
Do people think it would have a significant impact or only a minor impact?
I would prefer to do this over spending C$7500 Canadian dollar on the better cooling front brake kit from AP Racing / Essex
Since I’ve put supercar 3R tires on my car in Hawk DCT 70 pads, my pedal has gone to the floor twice while slowing down for corners and it has scared the crap out of me, granted both times it happened I did not take a full 40 minute break between tracking sessions. However I want to have complete confidence in my brakes at all times, within reason.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 11-02-2020, 08:59 PM   #2
Baddawg53
Drives: 17 hyper blue 2SS M6
I boiled the fluid the first time I was at the track. I had just put the 6 piston fronts on my car. I changed the fluid to motul 660, added titanium shims, and the SS cooling deflectors. Haven't had an issue since, gained a lot of confidence in them.
Baddawg53 is offline   Reply With Quote
Old 11-02-2020, 09:16 PM   #3
GunMetalGrey
What six piston brake kit did you put on your car?
Yes I should try titanium shims. That and some cooling fans between sessions.
I already have Motul 660
Old 11-02-2020, 10:00 PM   #4
Baddawg53
I put the 1LE 6 pistons on the front on my SS. Stock 1LE pads, supercar 3's. Obviously my braking technique needed help, but at my speeds I should not have boiled the fluid. It's not 3R's and hawk pads, but I assume by the time I get to that level my braking will be much improved.
Old 11-02-2020, 10:17 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I run the 6 piston Z06 setup on my 5th Gen SS an when I’m at the track I have 2 box fans that I put right up next to the tires to cool the brakes between sessions.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 11-02-2020, 10:26 PM   #6
GunMetalGrey
Yeah I think that’s too many differences to make a apples to apples comparison between our cars.
Old 11-02-2020, 10:52 PM   #7
Baddawg53
Oh I agree!!! My point was the size of the SS deflectors and the smaller backing plate should help in any setup ... More air will never be bad. And for the price, it's a no brainier.
Old 11-03-2020, 12:18 AM   #8
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
First and only mod on my 2019 ZLE was to swap out the small oem brake deflector with the larger SS unit. Muuuch bigger. And cheap as shit. $37 for the pair. I was sold on this solution even before I bought a Camaro. I know the owner of Vorshlag and he once pointed me to some testing he performed on Mustang cooling options. Net - the brake cooling deflector beat a 4" hose system every time. By and average of 100f.
Full article
https://vorshlag-store.com/products/...-deflector-kit
Pcormier66 is offline   Reply With Quote
Old 11-03-2020, 02:11 PM   #9
GunMetalGrey
True! I did order those parts but forgot to put them on before I tracked last weekend, I wish I had remembered so I could have seen how much of a difference they make
Old 11-03-2020, 02:12 PM   #10
GunMetalGrey
Full article
Wow Good to know! Thanks I’ll check out that article for sure!
Old 11-03-2020, 02:14 PM   #11
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yup i have 1ss with zzp bbk and i kept the brake duct kit from the factory that was in the trunk on
motul 660 fluid goodridge lines oem pads and rotors for now no problems on track
kropscamaro16 is online now   Reply With Quote
Old 11-04-2020, 12:19 AM   #12
TrackClub
TrackClub's Avatar
Put the shims and SS deflectors as suggested. No reason whatsoever for you to run DTC70s tho, which will put out tons of heat regardless of what you do. Id go down to DTC60s if you want more bite vs stockers. Or Ferodo 1.11.
Then, id swap the Motul for SRF and if you cannot get it, try Willwood EXP as it is VERY good.
Lastly, dont kid yourself about AP solving heat issues from high torque pads. Been there done it. Stock Brembos are mighty enough. Just reduce heat and improve brake fluid (plus shims and deflectors).
Cheers!
Old 11-04-2020, 12:27 AM   #13
cdb95z28
cdb95z28's Avatar
Using titanium shims with OE pads probably is not a good choice. Using the titanium shims slows heat transfer into the caliper, which means it will stay in the pad. This could lead to pad fade.
But you are running the Hawks so running the titanium shims could be beneficial.
"KEEP THE FAITH"-Fbodfather
cdb95z28 is online now   Reply With Quote
Old 11-04-2020, 09:32 AM   #14
racerx8
racerx8's Avatar
Drives: '18 1LE '16 Z06 '22 Z51 '23 Z06
TrackClub I agree 100% Stock 1LE calipers, DS1.11 pads (f&r), Ti shims, SS deflectors, Motul 600. Zero fade issues, LRP, the Glen, Thompson and out brake some P$$ cars, and a lot of others etc. Manage the heat in your 1LE brakes properly and they work great.
racerx8 is offline   Reply With Quote
