Old 10-19-2017, 12:38 PM   #71
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Originally Posted by Eric SS View Post
With MRC and 19” wheels you can’t get more than about -1.6* without clearance issues (spacers/studs can get you more). Plus, I like being able to set the camber when I get to the track and setvit back to street before I leave.
Ah ok that makes sense
Originally Posted by TEX1LE View Post
If you leave the car stock or with minor mods -2.5 will be okay. Once you start running slicks and have a lot of suspension upgrades you'll
need more than -2.5. Just depends on what you want to do with your car.
"Will be ok" is relative hehe I guess Ill try -2.2 ish next track day and see what happens to my tires, 2 trackdays (5k miles total) is a bit short on tire life hah.
thescreensavers is offline   Reply With Quote
Old 10-19-2017, 01:21 PM   #72
TrackClub
TrackClub's Avatar
Well not exactly: tons of folks here run slicks on stock cars either with spacers and/or grinding to accommodate 2.8 to 2.9F camber. At that, the inside will likely cord. So adding even more camber will likely cord inside even faster. Heck, I almost corded inside F with 2.6. But clearly it will be tires and track dependent (to a degree).
PS Zero toe issues with my alignmenmt specs
Old 10-19-2017, 01:24 PM   #73
TrackClub
TrackClub's Avatar
I wouldn't hesitate for a second to max the F camber to protect the outside edge. 2.6F and 1.6R IMO is a very nice compromise for a DD track car.
Old 10-19-2017, 02:38 PM   #74
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
I would honestly max it out. I'm maxed front and rear. Front is wearing pretty evenly, the rear is wearing the outside edge quicker. I'm at 5k miles and 5 track days and the tires are just about done, which IMHO is pretty good longevity for these tires.
This. I wish we could get even more rear camber stock though.
RXtacy is offline   Reply With Quote
Old 10-19-2017, 03:38 PM   #75
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
BMR toe rods are a must for our cars.
Eric SS is offline   Reply With Quote
Old 10-20-2017, 11:11 AM   #76
thescreensavers
So that you can dial more rear camber and get toe in check?
Old 10-20-2017, 11:33 AM   #77
Eric SS
#becauseracecar
Eric SS's Avatar
Yes. You can crank the cam bolt all the way and still keep toe in check.
