Old 02-21-2017, 09:39 PM   #71
eric0353
eric0353's Avatar
Drives: 2017 Camaro 2SS
yup, i put tape over all 4 plastic squares and the rattle is now gone when playing heavy bass music
2017 2SS Camaro - M6 - Hyper Blue Metallic - White Pearl Rally Stripes - Khalari Interior - Khalari Knee Pads - NPP - Sunroof -
eric0353 is offline   Reply With Quote
Old 03-27-2017, 11:05 AM   #72
stevstevd
Drives: MBM 2016 2LT RS
I've got this same rattle... What;s the easiest way to remove the square plugs? I put tape over one that was really loose and while it helped, the rattle is still there at times... Perhaps the other plug might need to be taped... I just want a better solution and others seems to have removed, than replaced with towel, etc...
stevstevd is offline   Reply With Quote
Old 03-28-2017, 11:13 AM   #73
chrest
chrest's Avatar
I used electrical tape on mine and kinda pulled it tight before sticking it to the other side so it kinda holds them firm on there. Solved my issue. I did tape all of them even though only 2 were "loose"
I doubt it would hurt too much to just remove them though, but i would bet you might have something else rattling if the tape didnt solve.
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 03-28-2017, 11:19 AM   #74
eric0353
eric0353's Avatar
the rattles come from the underside of the doors... there are plastic square pieces that are smaller then the hole they go into which causes the rattles. put tape over them like i did and the rattles disappear
Old 03-29-2017, 01:09 PM   #75
stevstevd
Mine almost disappeared, but not quite. the one i put tape on was completely loose - wasn't event in all the way. I suppose I could just tape the other, but I am not convinced the tape will fix it completely as there is probably a small bit of looseness even with the tape - some of the vibrations would still rattle things especially since mine was so loose - unless I can get it out and secure it a little better. I just don't want to break anything trying to pull it out.
Old 03-29-2017, 01:12 PM   #76
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Nobody has yet explain the removal process... the ones that fixed it (besides just throwing tape over the butt end is the plug) have mentioned removing & wrapping it with flocking tape (not sure what that is but ok)... hopefully they can come back here & explain it... Just like stev, I also don't want to just yank it out without hearing from the ones that have already taken it out.
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 03-29-2017, 07:22 PM   #77
NY Andrew
NY Andrew's Avatar
Drives: 2016 Camaro V6 2LT RS Fully Loaded
You can ply anything under it. I used my fingers to yank it out. The side may get a little smashed or not look as pretty but who cares as long as it stays in secure and doesn't rattle because no one will see down there anyway. Best way I can describe what it looks like: say a 3 inch diameter square with a 2 in diameter one inside; that's all it is.
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15
My 2LT Review/Pictures/Mustang Comparison
My 2016 Camaro Bose Subwoofer Install
2016 Camaro V6 Stock to Borla Atak Exhaust Sound
2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak
NY Andrew is offline   Reply With Quote
Old 03-30-2017, 06:08 AM   #78
stevstevd
Ok, so it sounds like no risk in just trying to pull on it. I wasn't sure if it was in there like an anchor in drywall or something and as soon as it pulls out things snap or something.
Old 03-30-2017, 04:46 PM   #79
NY Andrew
NY Andrew's Avatar
It's literally not connected to anything. Just sits in there. You're welcome.
Old 03-31-2017, 05:30 PM   #80
stevstevd
I taped them all up, still seems to rattle. I feel like the rattle is more within the door arm rest, perhaps around where the plastic meets where the lighting strip starts. Not sure.
Anything with even the slightest base will rattle it. I have base set to about 25%. and volume similar. It does come and go though, although I can always replicate it by setting base to 50% on any hip hop station on xm.
Old 03-31-2017, 06:15 PM   #81
NY Andrew
NY Andrew's Avatar
It's the panel itself. If you push it real hard when you're bass is playing it should stop the rattle. But only way to fix it is to layer that whole panel by taking the entire door panel off...on my to do list but dreading it..
Old 03-31-2017, 09:52 PM   #82
keon718nyc
Yes i have to also say that after taping down the plastic pieces on the bottom of the doors that the only other place i hear a rattle would be the door panel itself and i pushed on it hard and went away like you said. I will see what i can possibly put in between the door to stop that the next day or so. Its not too bad when the volume is up high but on lower volume bass can be annoying with that creaking noise.
Old 04-01-2017, 10:39 AM   #83
NY Andrew
NY Andrew's Avatar
Share any possible solutions/progress! Thanks!
Old 04-02-2017, 06:44 AM   #84
stevstevd
all the same symptoms as mine - except higher volume just amplifies it.
Sometimes pushing the panels actually stops it for a bit until things rattle out again. Since I am not really experienced with this sort of thing, all I can really do is hope the dealer can fix it without telling me to turn my base to zero.
