#57 | |
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband. |
#58 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
I would not port the lt5 tb
#59 |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
I just installed my ported LT2, ported 87-95 Katech adaptor along with a ported LT5 TB. I haven't dyno'd her yet, but I did do a street tune. Based on my experience, do it!! It's all about how the porting is done and who's tuning the car. Most of the people that are saying not to do it, haven't had it done, they're just going by what is posted. Not saying that the previous poster hasn't had the same setup, but just saying.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit |
#60 | |
I saw Jannettys last post that the tb tables were recently added to hpt. Prior to this, I found the 95mm tb and ported 87tb were at the limit before needing massage other tables to compensate. I found the tradeoff of porting the 95mm tb not being there but perhaps that not being the case now. I guess I should buy another ported 95mm as I had soler 95 and pray 95 units before for my own testing. |
#61 |
Finally worked these tb tables. 5 mins and running better already.
#62 |
so you are recommending ported LT5 TB?
#63 |
Now? Yes if you don’t mind spending the money.
#64 |
Absolutely worth it, yes, if you don't mind spending the money
#65 | |
![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
#66 |
nvm, i found what you are talking about on the hptuners forum.
#67 |
https://forum.hptuners.com/showthrea...e-body-vs-95mm
One of the few comparisons for TBs. 10hp on 416ci that I would assume has heads and cam and this is comparing a stock 87mm vs 103mm.
#68 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
