Old 07-18-2023, 06:55 PM   #1
Dmoney2SS
Drives: 2022 summit white Chevy Camaro 2SS
LT5 (95mm) throttle body port or no
Is it worth porting an LT5 throttle body or could I get away with an unported 95mm? I’m planning on just doing a simple bolt on build for now, that being lt2 manifold 95mm tb and possibly a rotofab, also would I need a spacer for it or would it bolt right up?
Dmoney2SS is offline   Reply With Quote
Old 07-18-2023, 07:26 PM   #2
6spdhyperblue
Drives: 2SS 1LE
I run unported lt5. I tried a few different ported lt5s.
Old 07-18-2023, 09:37 PM   #3
Dmoney2SS
Was there any difference?
Old 07-19-2023, 06:37 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Run the unported 95. Ported versions can be a nightmare to tune and aren’t worth the aggravation. If you need more airflow than a 95 then simply buy a 103.
Old 07-19-2023, 06:31 PM   #5
Dmoney2SS
Do you know if I need a spacer to run it? With an LT2 IM
Old 07-19-2023, 06:52 PM   #6
Fstlane
Drives: 2019 Summit White ZL1
189 bucks on Rock Auto....genuine GM part
Fstlane is offline   Reply With Quote
Old 07-19-2023, 07:10 PM   #7
6spdhyperblue
Drives: 2SS 1LE
U need a spacer unless you widen the holes on the throttle body and then port the throat of the intake and cut beyond the o-ring
Old 07-19-2023, 08:27 PM   #8
Fstlane
Ok to try to provide some clarification. I have a stock LT5 throttle body from Rock Auto it is a GM Stock part on a ZL1. I used an adapter plate from
https://www.solerengineering.com/generalmotors.
Car runs great....still in the process of tuning and I have not had the car on a dyno yet as I am still adding a few things.
Listen to Josh....he knows what he is talking about.
Old 07-19-2023, 08:45 PM   #9
Joshinator99
Moderator
Thanks Fstlane.
I think that adapter actually looks pretty good…less restrictive than others I’ve seen.
Old 07-23-2023, 11:37 PM   #10
Daily1LE
Daily1LE's Avatar
Drives: 2018 Camaro 1SS 1LE
Just curious, is there any benefit at all with a 95MM LT5 TB mated to a LT1/2 IM? Both have to be choked back down to 87mm so I wonder what is the point of the 95MM TB?
I just picked up a LT2 IM manifold myself and am in this similar debate on if I run my stock TB or a LT5, but failing to find any reason to run the LT5 on a stock LT2 IM.
2018 1SS 1LE - DSX E85 Kit | Full ARH Exhaust | RotoFab CAI | Katech Cam | Katech Ported Stock Heads | Tuned - 530HP/456TQ
Daily1LE is offline   Reply With Quote
Old 07-24-2023, 06:15 AM   #11
6spdhyperblue
Drives: 2SS 1LE
If the lt2 is ported, the throat should be larger than 87mm
Old 07-24-2023, 07:43 AM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I can attest to ported LT5s can be over-ported pretty easily and the resulting tuning necessary to get it to behave can be not fun...
'20 ZL1 Black "Fury"
Old 07-24-2023, 09:10 AM   #13
EliteLT1
EliteLT1's Avatar
Drives: 2022 Camaro LT1
mm
I'm running the LT2 IM unported, with the 95mm throttle body, also unported.
My logic (shoutout to EssMotorsports on youtube) is that for any throttle position besides WOT, the larger throttle body will allow more air to flow. For example, you will get more airflow with a 95mm TB at 50% throttle than you would get with an 87mm TB at 50% throttle. Probably more of a throttle response benefit in this case
At WOT, the 87mm TB still has the plate and shaft blocking part of the opening (effectively reducing airflow below a true 87mm opening), while the IM opening is always the full 87mm diameter circle. In this case the TB is the limiting factor for airflow. Going to a 95mm would make the IM opening the limiting factor
Unless I'm misunderstanding how they measure the TB, this makes sense to me. But I don't have any comparison numbers isolating only the TB differences
EliteLT1 is offline   Reply With Quote
Old 06-08-2024, 09:06 PM   #14
wang970305
Drives: 2021 Camaro 2SS
Originally Posted by EliteLT1 View Post
mm
Im confused... the IM opening is choked back down to 87mm, how come the 95mm TB would work better than the stock 87mm tb
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
