Old 08-12-2021, 02:31 PM   #57
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by parish8 View Post
You just wire the coils over to the holley. All the other stuff you all ready did to run the fuel is done.
I went ahead and checked my base timing once it was on the 2nd ecm and it was exactly where I expected it to be.
Once the timing is over on the new ecm you have some nice safeties you can turn on.
What are you moving to next since you are trying to sell the Camaro?
Old 08-12-2021, 03:21 PM   #58
parish8
Drives: 17 SS a8
I am taking my time building a gen v sbc powered mustang but that is happening weather I sell the camaro or not. I am looking to sell the car to help finance a business opportunity
Old 08-12-2021, 08:38 PM   #59
KingLT1
KingLT1's Avatar
Right on...That looks like a killer build!
Old 10-31-2021, 01:47 PM   #60
Tooquick2beslo
Drives: 2017 Chevrolet camaro
(Sorry for bringing up an old thread)
How much rwhp are you making with this setup?
Power Adder: Whipple 2.9 with 3.375 pulley. Produces 9psi peak in 70+ degree weather @ 2k da.
Fuel system: LT4 injectors, LPE DI pump, LT4 tank pump with JMS booster.
Other mods: Ported LT5 Throttle body, Rotofab big gulp, Flex sensor, CA cat delete pipes, Borla 60608 x pipe into Corsa NPP.
Dragy Performance time: Street pull, second gear launch(A8), the car ran 1.75 60ft, 3.0 0-60, 6.17 0-100, 6.9 @ 107 1/8 mile 10.5 @ 135 1/4mi full weight on 20's with a 305/35/20 Nitto 555r2 drag radial.
Log Data: Running E55, My High side pressure holds 27-2900psi, Low side pressure holds 70psi, Injectors 5.6-5.7ms in 70 degree weather. So the fuel system is holding fine.
Longevity: In 3yrs I have logged 8k miles of drive time and easily a 100+ 0-60, 0-100, 1/8, 1/4 and wot pulls from a roll...no issues so far knock on wood. Lol
Tooquick2beslo is offline   Reply With Quote
Old 11-13-2021, 07:50 AM   #61
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
so old thread but i found it interesting..
anyhow..
is the consensus that drop in pistons solves the ringland and 600 whp barrier for stock lt1 block?
if so what seems to be the best option in that dept?
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 11-13-2021, 08:27 AM   #62
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
anyhow..
The GPI setup is working well for me.
https://gwatneyperformance.com/produ...n-rod-package/
Old 11-13-2021, 09:11 AM   #63
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by lcarney1977 View Post
like the title says how much rwhp can the LT1 motor handle be4 you gotta beef it up?
I would call Hennessey or KaTech for an answer.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 11-13-2021, 09:53 AM   #64
biker2k
biker2k's Avatar
im thinking drop ins are in my future?
just so i dont frag this motor
Old 11-13-2021, 10:47 AM   #65
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Did you actually install them without balancing the RA?
How difficult was it to gap the rings correctly? Did you have to look out for specific things to make sure they fit perfectly?
What about honing the cylinder walls?
Do you see any excessive oil consumption after, compared to what is was when SBE?
Old 11-13-2021, 12:18 PM   #66
Joshinator99
Moderator
No balancing needed, weights were damn close out of the box. I didn't do the rings myself so cannot comment on that.
Car had exactly 5000 miles at the time of the build, so cylinder walls were perfect. Oil consumption is no different than when it was stock.
Old 11-21-2021, 06:12 AM   #67
appleman22
Drives: 2017 1ss 1le
Hennessy are a bunch of thieves and criminals LOL. Google "hennesrewed"
appleman22 is offline   Reply With Quote
