Old 06-14-2017, 12:46 PM   #1
lcarney1977
Drives: 2016 CAMARO SS
how much rwhp can the lt1 block handle?
like the title says how much rwhp can the LT1 motor handle be4 you gotta beef it up?
lcarney1977 is offline   Reply With Quote
Old 06-14-2017, 01:21 PM   #2
DenverTaco07
DenverTaco07's Avatar
it's a good question - I don't think there is a definitive answer that will be true in every case, but if you look at the history of LT1 in C7's and Gen 6 Camaros, you should be fairly safe at 600rwhp. I'd be starting to sweat a little at anything above.
There is one example of a youtuber guy...red racer or something (here's the thread http://www.camaro6.com/forums/showth...ight=red+racer), that his motor blew out on the dyno and the tuner had it under 600rwhp...just one example.
Edit - looks like he was 620rwhp at 10psi. My 1LE is going in next week for a vortech supercharger - I'm hoping for 550 at the wheels, 8 psi. should be good, but...YOU NEVER KNOW.
Old 06-14-2017, 01:23 PM   #3
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
that's disappointing...
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 06-14-2017, 01:31 PM   #4
ProCharger
Drives: Many C7's
Your title says "Block"
In which case, the fastst C7 Stingray (LT1) goes 8's with a ProCharger
As far as internals, well my personal rule would be anything above 650-700rwhp. The ring gaps inside these motors are so tight, its hard to safely make power above that without having a ring land failure.
I have made more, BUT you don't know how tights yours is.
And its a LOT easier to fix something (drop in pistons, or drop in rods/pistons) before the motor lets go.... cause after it does, you are replacing about everything.
ProCharger is offline   Reply With Quote
Old 06-14-2017, 01:37 PM   #5
DenverTaco07
But to be clear the C7 you reference has forged internals...right? Just to be clear.
If i'm just shooting for 550-ish, then should I really consider having to drop in forged pistons / rods (I think the piston rods are already forged though..on the LT1)
Old 06-15-2017, 03:04 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
My car has seen over 7000 miles over 650whp. I owned it less than a week before it got turbos. The internals are all stock. I don't daily drive it, it is a toy. When it leaves the garage I usually run it hard. No problems yet. If you stay below 700whp the stock motor should be fine.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 06-15-2017, 03:47 PM   #7
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
What do you mean by block? Stock block with stock internals? Stock block with forged internals? Short block? long block? I dont think this question is very clear and is why you dont have a clear answer.
Turbo_RORO is offline   Reply With Quote
Old 06-15-2017, 03:59 PM   #8
parish8
Drives: 17 SS a8
Question was vague but the answers covered it either way.
Stock block is good for 1000+hp with upgraded internals.
Stock short block is good for somewhere between 600 and 800 depending on who you ask.
Old 06-15-2017, 04:43 PM   #9
DenverTaco07
Nice...good to hear.
Old 06-15-2017, 05:27 PM   #10
jessrayo
Speed Freak
jessrayo's Avatar
When the LT1 engine first came out in the Corvette there were some failures related to residual metal in the oil at engine assembly,
http://www.autoblog.com/2014/09/08/c...rouble-report/
but this seems to be pretty much eliminated by the time Camaros got the engine. Occasionally a stock engine will fail. Quality control tries to prevent this but every once in a while something slips through. If you just happen to get an engine that was going to eventually have problems in the stock configuration it will definitely fail when you increase the power by 50 to 100% Problem with modding an engine is once you touch it, it will not be covered under the original warranty so if the motor frags you buy a new one.
The engines are pretty good from the factory and I think 99% of the people that go to 600whp will never have a problem but there will always be some exceptions. There are a lot of LT1 piston and piston ring failures documented around 700+whp. You can google "LT1 piston failure" and see plenty of pictures and stories. Most of them are over 700whp some are not. I'm running my car 650whp because of this. I could make more but that's where I feel I won't be buying a new engine for my SS. Now my '13 ZL1 is on its 4th engine..... They don't hold up very well over 1200+ whp and going 200mph.
Hope this answers your question
Old 06-15-2017, 09:25 PM   #11
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
The biggest issue with a piston/ring pack failure is mostly due to builder negligence. When you go from an N/A engine to FI engine, or power adder engine, is the rings need to be gapped for the usage. An N/A engine runs a tight ring gap due to the fact that the cylinder pressures are fed by what the engine can injest. When you start forcing additional oxygen into those cylinders and adding the appropriate fuel, the pressure rises accordingly. When that happens the ring ends are bound to butt up against one another. I don't think you can blame a manufacturer for gapping the rings appropriately, then the end user increases combustion pressure and the piston ends up breaking as a result.
If they're gapped appropriately and the forging itself breaks, you've obviously exceeded the structural limitations of the design. Again, not something you can blame on a manufacturer for their material choice, especially when you engine is makingjust short of 200% of the original design.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 06-16-2017, 02:25 PM   #12
GuywithL86
Drives: Black
Would not be surrised if the long block could handle well over 1k hp if not for the ring gap issue
GuywithL86 is offline   Reply With Quote
Old 06-16-2017, 07:24 PM   #13
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
We are a full texas speed 416 stroker build with cam and valve train to match.
Turbos are 6266 bb turbonetics and we will have fueling for 1600whp. We're aiming for 1200-1500whp (stock sleeves)
I hope I'm not the pioneer to find the stock sleeves breaking point hahahah
Goertz is offline   Reply With Quote
Old 06-17-2017, 01:09 AM   #14
Turbo_RORO
Turbo_RORO's Avatar
I hope you make it to 1600. That turbo kit is coming along great.
