Old 04-07-2017, 06:18 AM   #57
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
Does anybody know the size of ring terminal needed for that 200A stud on the battery?
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 05-14-2017, 12:23 AM   #58
Alfieboy
Madman
Drives: 2017 1SS
wrong
Originally Posted by RobsCountach View Post
Exhaust note only plays into system on the Bose setup...
on non bose 1ss also..............
Alfieboy is offline   Reply With Quote
Old 05-14-2017, 05:43 AM   #59
Tankman
Tankman's Avatar
Drives: 2017 Camaro 1LT 2.0 Turbo
On the 2.0 turbo 1LT model too??? If yes pls explain.
TIA
Tankman
Tankman is offline   Reply With Quote
Old 05-14-2017, 10:20 AM   #60
NY Andrew
NY Andrew's Avatar
Drives: 2016 Camaro V6 2LT RS Fully Loaded
Can someone record this "ANC noise" coming from their speakers? Not sure if I am or have experience it with my system because I never touched any aspect of ANC. I think I hear some noise sometimes, but not sure if that's it. Also unsure how to properly disconnect it.
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15
My 2LT Review/Pictures/Mustang Comparison
My 2016 Camaro Bose Subwoofer Install
2016 Camaro V6 Stock to Borla Atak Exhaust Sound
2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak
NY Andrew is offline   Reply With Quote
Old 05-15-2017, 09:11 PM   #61
Alfieboy
Madman
Drives: 2017 1SS
get a sub..you'll know right away..
Old 05-15-2017, 09:17 PM   #62
Alfieboy
Madman
Drives: 2017 1SS
the noise is gone from sub when disconnecting the green with black stripe..and the blue with black stripe as noted here in forum. I have plug back in..all works way supposed to...just no obnoxious resonating of sub now..
Old 05-15-2017, 09:28 PM   #63
NY Andrew
NY Andrew's Avatar
I have a sub boy if you read. 2 12 rockfords. So I'd have to cut those wires now too. Confused why you disconnected and then plugged back in and it worked with no noise, doesn't make sense to me.
Old 05-16-2017, 10:46 AM   #64
ctrlz
I have not looked up the color codes, but I'm guessing he cut one wire for each door microphone which is all that needs to be done. Put the plug back in so you retain door chimes, turn signals, etc.
Old 05-16-2017, 12:00 PM   #65
wal-dog
Drives: 2016 Garnet Red 1SS
Is this taking the stock amp, out of the signal. Splice out before, Splice back to speakers ? Looking which wire, of the plug, is signal in and which is speaker out ?
Also, does not utilizing Pins 1 - 4 & 9 - 12, remove the bass (low level signal) ?
I have a 1LT. Might not even be same colors, but do have Amp in trunck.
Pins 1-4 and 9-12 are the signals coming from the head unit to the amp. All the other pins are are going from the amp to the speakers. The stock amp is still in the mix. You take the wires that were going to the speakers and instead send them to the LOC. The LOC turns those signals into usable RCA's and you'll all set to do whatever you like with them.
wal-dog is offline   Reply With Quote
Old 05-17-2017, 07:12 PM   #66
NY Andrew
NY Andrew's Avatar
I have the 2LT and only have one black plug with one wire in it. Disconnected it, blinker noise was gone, from what I could tell almost looked like less booming/buzzing noise, but it through a CEL.. that happening to you guys too?
Old 05-19-2017, 11:55 PM   #67
Alfieboy
Madman
Drives: 2017 1SS
noise
unplugged..
cut wires..
plugged back in...
green with blk
blue w/blk
Old 05-19-2017, 11:56 PM   #68
Alfieboy
Madman
Drives: 2017 1SS
not sure of Bose..i have 1ss no Bose
Old 05-20-2017, 03:23 PM   #69
davef
Drives: 2017 SS 1LE Garnet Red
Anyone know if a 1SS 1LE has the ANC system? As far as anyone has been able to tell, there's no amp in the 1LE non Bose system.
davef is offline   Reply With Quote
Old 05-22-2017, 07:39 PM   #70
brianhj
Drives: 2017 Camaro 1SS
Here's what I'm not understanding:
You guys are adding another 60+ amps (depending on the size of the subwoofer aftermarket amp) to another fused circuit? That's potentially 260A on a circuit designed for 200A, correct? Shouldn't the sub amp have it's own wire directly from the battery terminal?
brianhj is offline   Reply With Quote
