05-18-2021, 11:04 AM | #57 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Pretty good video on catch cans from a non-biased source.
05-18-2021, 11:09 AM | #58 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Does anyone have any photos of "coked up valves" and "oil covered bricks" they can share?
I come from owning an RS4 which had this issue, I would clean the intake valves every other oil change. The biggest source of the problem was leaky valve seals. And from what I've read from multiple sources, the LT4's have valve guides that wear abnormally fast, kind of like the LS7's did/do. This might allow oil to seep past the seals and down onto the backs of the valves.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
05-18-2021, 11:10 AM | #59 |
Drives: 2010 Camaro Join Date: Nov 2009
05-18-2021, 11:15 AM | #60 |
Drives: 2018 ZLE M6, '15 CLS 63s AMG Join Date: Jun 2017
I was told "skipping the catch can was a back fire" and had to have a catch installed after blowing out my front crank seal because I didn't go with it as suggested. Also upgraded to the "LS style seal as it’s a better design", adding a catch can to help vent crankcase pressure to prevent any future failures is how it was explained to me so I went with it. I got the Mighty Mouse Wild Catch Can they did a nice job with the install, it almost looks factory. I'll post some screen shots of the install when I get a chance.
05-18-2021, 11:30 AM | #61 | |
05-18-2021, 12:13 PM | #62 | |
Drives: 2023 SS 1LE Join Date: Mar 2020
Scroll down to post #4, Bill Dearborn’s post about his supercharger on his LT4 Z06. He has 15k miles on it at the time of that post, with 5k miles being hard track use. Check out how there really isn’t much oil there and the pics of the valves stems doesn’t look bad either. |
05-18-2021, 12:43 PM | #63 |
Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
What's funny is I haven't really heard anyone saying they don't work. The question is are they needed? That's an individual choice, do your research and see if you think they are worth it given the drawbacks, perceived or not. I own two supercharged Camaros, I have a catch can on my 2010 which does it's job well. It was installed four years after the car was built. When I installed the blower the vehicle ran strong and had no problems (didn't need a walnut shell blasting) . I have a catch can now and the vehicle still runs strong (built in 2009).
When my warranty runs out on my 2021 Ill probably install one on that car also. I'm just not that concerned about it on a new vehicle given the drawbacks, again perceived or not.
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 |
05-18-2021, 12:49 PM | #64 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
05-18-2021, 12:52 PM | #65 | |
I've already posted a great video showing who catch cans work and why they're recommended. That's based on real world results from a non-biased party. I don't think you're going to find any better proof than that because this is just not a subject that the community wants to spend a lot of their own time and money researching. |
05-18-2021, 01:07 PM | #66 | |
Thank you Al Oppenheiser!
Many folks in this community will agree that catch can's work (title of this thread), but many of us will also agree that we're not interested in: a) voiding the warranty on our stock cars with just a catch can. b) taking time and effort and money to solve a "problem" that doesn't really matter to us, even if it exists. In 2015, Chevy made changes to the gen5 LT4 that dramatically reduced the rate of carbon buildup on the intake valves. To date there has been very little evidence* of any measurable performance degradation on stock 2015+ LT4s due to missing aftermarket catch cans. Aftermarket modified/tuned/boosted LT1 and LT4 engines with obviously voided warranties are an entirely different subject and often do benefit short and long term from including a catch can in the build. * actually, there is no evidence. |
05-18-2021, 01:31 PM | #67 | |
Considering most top shops install a catch can as part of their packages tells me that they believe they have purpose. They're clearly not installing them for no reason. When you deal in high performance cars for a living including the tear down and rebuild of these engines, I'd say they there must be a good reason to install them with their packages. I'd consider their experience more valuable than the average Joe ZL1 owner that only changes the oil in their car. Just my opinion. |
05-18-2021, 01:39 PM | #68 |
Drives: 2021 Chevrolet Camaro ZL1 Join Date: Apr 2021
Ok so the video "proves" that if you completely reroute and eliminate the PCV system you get less deposits. Notice there was still some deposits that occur anyway.
Its measured in mg, over 10,000 miles but what difference does the catch can make? from this video I just want to run the PCV valve into the environment like my 1984 Hyundai Pony was HAHAHA
2021 Camaro ZL1
ADM S/C Expansion Tank Dual Aeroforce gauges Eibach Pro Lowering Kit Oracle Side markers (Paint matched) Rear window "wind screen" Xpel Paint Protection Ceramic Pro Coating |
05-18-2021, 01:58 PM | #69 | |
05-18-2021, 02:19 PM | #70 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
L83 on 0W-20, 9~12k-mile OCI, no catch can at 117k miles. These conditions are much tougher than what most LT1 will see. So at least for NA folks, don't lose sleep over it. Not sure if there has been any pics for LT4. I will leave it to ZL1 or boosted LT1 folks. As for oil contamination, this is something you will have to see with UOA, as mentioned before. I don't quite see why DI would be worse than PI in that regard, unless GM's design is as flawed as Honda's L15B7 found in Civic's, Accord's and CR-V's, where a lot of fuel gets sprayed at the cylinder wall and drip down into the pan when the engine is cold. So far, there has been no report of GM engines doing that, and even Honda's that have apparent fuel dilution don't seem to have mechanical issues related to this. As for emissions, remember that one thread where someone is offered 500 bucks for having their Camaro SS dynoed for emissions? If DI engines that don't include walnut-blasting can't hold up long-term, wouldn't the manufacturer be in trouble from these dyno runs?
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
