Old 03-11-2025, 06:09 PM   #43
SamSmoothCastel
Drives: 67 Orange Mustang Coupe
If anyone needs the real authentic GMP CAI CARB sticker, I just ordered (and received) the real GM sticker for $14 delivered from GMPartsStore.com the part number is 84152144 (this was exactly the label for my 2020 2SS with the GMP CAI) I wanted a new label because when I first got it I stuck in on the hood (we all do dumb things) and it makes MUCH more sense to put it on the back of the actual Cold Air Intake, the item wasn't on back order but they had to get it from the warehouse, etc, took about 10 days but the legit, authentic real GM label showed up, for $14 including shipping!
Here was my original mistake...
Here is the order for the new one and the new sticker which is 100% identical to the original one...
Got some bad news. You understand the one you bought is for a V6 Chevy Colorado, right?
SamSmoothCastel is offline   Reply With Quote
Old 03-11-2025, 06:30 PM   #44
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
No, it is identical to the one that came with my Cold Air Intake, same exact numbers...
Here is the old one I pealed off my hood that came with my OEM GM Performance Cold Air Intake for my 2020 2SS that also came with the tune the dealer installed.
Here is the new replacement sticker I ordered and received...
Same Same... and only $14...
Old 03-11-2025, 07:36 PM   #45
Matt1LE
Matt1LE's Avatar
Drives: 2020 3LT Camaro 3.6L 1LE
I really, really hate Komifornia... Can't wait to leave in about 2 years...
The itch is getting to ya?
Matt1LE is offline   Reply With Quote
Old 03-11-2025, 07:46 PM   #46
2SS Capt
2SS Capt's Avatar
It's been for many years, getting closer everyday!
Old 03-11-2025, 08:43 PM   #47
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
I wonder if that sticker would work here in New Jerkey on say a Roto Fab? This state is just as bad as Cali. They only do the smog test and occasionally pop the hood during state inspection every 2 years. It would probably fail the probe up the tail pipe I guess.
STYLO LT1 is offline   Reply With Quote
Old 03-12-2025, 05:55 AM   #48
clg82
Drives: 2020 Camaro ZL1
You from San Fran?
Old 03-12-2025, 07:18 AM   #49
SamSmoothCastel
It doesn't matter what you peeled off - its the WRONG cert - just trying to help
84152144 is for a 2015-2022 COLORADO. Can almost bet the dealer grabbed a random sticker laying around at the time of install. This just goes to show that if you have been passing smog they don't even verify part numbers on the visual.
The F Label is just incorrect for a 2020 6.2 Camaro -
https://www.docdroid.net/DP6MV5T/843...structions-pdf
DM me your mailing address and ill send you the proper CERT for FREE
Old 03-12-2025, 11:48 AM   #50
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
GM put all their EO's on one tag at a time, but often had to re-submit every year. Here is the EO #126-44 from the CARB website. It lists only 2016-2019 Camaro. Technically, it has to be the GM part (not the Cold Air inductions part!), and you have to have the calibration installed. I am not sure when the part was discontinued, so I am not sure the EO ever got past 2019. At some point they switched to only being able to order the induction kit with the vehicle, so there wasn't an EO because it was a original equipment, then they dropped it shortly after that.
https://ww2.arb.ca.gov/sites/default...o/d-126-44.pdf
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 03-12-2025, 11:54 AM   #51
SomeGeoffGuy
If you have a 2020 and it came from the factory as a Cold Air Induction kit, then you should have an RPO for it (RVK I think?) plus it would be on your window sticker. That is super rare! But also it is why you didn't have an EO sticker from the factory - it was OEM. The approval for the kit was submitted when they submitted the FMVSS approvals for the entire vehicle.
-Geoff
Old 03-12-2025, 11:56 AM   #52
2SS Capt
2SS Capt's Avatar
It is the right label, I ordered the CAI from GM and installed it myself, the Executive Orders cover more than just one model of vehicle. I ordered my Camaro in late 2019 and bought the CAI at that time...
Old 03-12-2025, 10:09 PM   #53
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
GM got an intake certified for the Chevy Snooze but not the 4 or 6 cyl. 6th gens... :-/
Old 03-13-2025, 10:06 AM   #54
SomeGeoffGuy
Technically, the EO you posted isn't valid on a 2020 model. If you have a 2019, it is.
-Geoff
Old 03-13-2025, 11:11 AM   #55
SamSmoothCastel
My offer stands @2SS Capt - Its oaky you saved $6 bux over mine but ill still send you the correct cert for free.
Old 03-13-2025, 11:37 AM   #56
2SS Capt
2SS Capt's Avatar
Actually I saved $11 since you were selling the sticker for $25 and technically your sticker only covered 2016-2018 since it says D-126-43, so no, it isn't the correct one.
