Old 01-18-2025, 07:58 AM   #43
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Originally Posted by vince3 View Post
This is a legit question, if stock heads/cam Na doesn’t benefit from the TB, then why do all the 500 plus rwhp and the fastest bolt on cars run big throttle bodies ? Is it something that only benefits high rams or are you saying it’s just little gains for the money? I can also link the posts in here with non header cars running MSDs and 103s putting down 480 plus rwhp.
lol 500+ rwhp bolt on LT1? I'd be interested in seeing that build and what Dyno they are on. And do they have before and after numbers, because that's all that really matters.
https://www.camaro6.com/forums/showthread.php?t=587847
https://www.camaro6.com/forums/showthread.php?t=577766
https://www.camaro6.com/forums/showthread.php?t=543424
https://youtu.be/j5iR4i4kEIc?si=N66IYx31PcGFcaCh
https://www.camaro6.com/forums/showthread.php?t=535959
Here’s the ones I’m thinking of. You just don’t see LT2 intakes with ported 87s hitting these numbers. 2 of them don’t even have headers.
But I guess they can just mess with dynos to show any numbers.
On a good day, a bolt on LT1 with a unported LT2 intake and stock TB picks up about 10 rwtq and 15 peak HP, but way up top near redline the HP gains would be closer to 20-30 rwhp. My point is the gains are from the LT2 intake manifold.
I guess I operate in a world where 20-30HP can be had with a stroke of the keyboard so I don't see the point of adding larger TB's to pick up single digit power in the power band where your shift point is.
as you liked to share examples, here is one: https://www.camaro6.com/forums/showthread.php?t=606822
We have done ported LT2 intake manifolds and 95mm TB's on LT1 cars and we have done stock LT2 intake manifolds with stock 87mm TB's on LT1 cars. Those guys go out to race and nether seems the have the advantage.
So there is no wrong answer, I just have my own opinion on this subject.
GM Gen V Calibrator
Old 01-18-2025, 08:08 AM   #44
vince3
Drives: 2022 Vivid Orange LT1-M6
Okay I’m cheating to get free info. There is a million dollar prize for the fastest bolt on car, every car weights the same, same wheel, tire and gear setup, you can’t cut or replace the hood, cars have the same torque converter, you can port intakes/TBs, and you can’t use custom made parts like hand built headers/intake manifolds, just off the shelf stuff. What bolt on combo in your opinion wins the race?
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 01-18-2025, 10:11 AM   #45
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
1 7/8 inch headers, Corsa NPP, standard rotofab wet, MSD intake manifold port matched to a Soler 101mm eff throttle body and smoothed runners, flex fuel and send it.
GM Gen V Calibrator
Old 01-18-2025, 10:38 AM   #46
vince3
This TB? https://www.solerengineering.com/generalmotors/95mm
With the MSD and TB, would you get the 103 to 95 adapter from soler?
Old 01-18-2025, 01:08 PM   #47
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
yes sir!
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 01-18-2025, 02:46 PM   #48
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Sorry, I meant get a 103mm TB. When I typed I was thinking about a ported LT2 with the intake port matched to a 95mm unit.
GM Gen V Calibrator
Old 01-19-2025, 12:40 PM   #49
s346k
s346k's Avatar
Drives: like an old lady
this never gets enough attention when people are looking for every last mph. i shifted my msd manifold bolt on m6 car at 6800 rpm.
at 6500, a stock msd was up 36 whp over a pp LT1. i upgraded parts on the car after the last dyno session, but only had dragy / hpt timer for data.
Old 01-20-2025, 03:33 PM   #50
Mantis-SS
Drives: Camaro SS
I'm running a 103mm Soler throttlebody with an MSD intake. I've run the LT2 with the solar 95mm combo prior to that.
Mantis-SS is offline   Reply With Quote
Old 01-20-2025, 07:00 PM   #51
vince3
Any dyno numbers or anything to compare? Was this a bolt on car?
Old 01-21-2025, 02:08 PM   #52
Jiraiya
Drives: ZL1 1LE - 2021 - Wild Cherry - A10
95mm TB on a ZL1
Have anyone tried 95mm tb on a zl1 without porting the snout (will be ported in future) but i wanna know does it makes any difference + have anyone dyno it + how’s the car with the adapter and please give me recommendations about the Adapters.
Why 95mm not 103? Because it’s half the price can get to 100mm with porting.
Jiraiya is offline   Reply With Quote
Old 01-21-2025, 09:16 PM   #53
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
95mm TB without opening up the snout will only give you limited gains. Better off running without the adapter if you can.
Old 03-20-2025, 05:05 PM   #54
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
FYI, regarding the Soler Engineering 95mm throttle body. I've been conversing with their CS over the past week to clarify a few things.
1) The current part number for this is SE9871-95ZR. It is now marketed as "95+ MM (Plus+Port.)" and not as "100mm Effective".
2) They do not use factory units for this, but aftermarket units. (unless special order or special request).
tortilla-flats is offline   Reply With Quote
Old 03-20-2025, 05:52 PM   #55
wang970305
Drives: 2021 Camaro 2SS
I have a 103mm TB for sale if you are interested
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
Old 03-21-2025, 08:06 AM   #56
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Why would you think I want to buy a used 103mm TB?
GM Gen V Calibrator
