![]() Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Dyno Test: Pray Ported OEM vs PP MSD Intake Manifold
The test mule is a 2018 Camaro 2SS 1LE. Basic modifications are a flex fuel sensor, Roto-Fab dry CAI intake, Soler Performance ported 95 MM throttle body, New Era Performance cat delete pipes and a tune. The intake manifolds tested are an OEM intake manifold ported by Pray Performance and an MSD LT1 Airforce intake manifold, also ported by Pray Performance. The car was tuned at Church Automotive( http://churchautotesting.com/ ) with all of the mods listed + the ported OEM intake manifold. On April 23 of this year we took the car to Superior Automotive's Dynojet to see where the car was with the tune-it made 464 HP and 468 torque.
We installed the Pray Ported MSD intake manifold in early June. We took the car to Natural Aspirations( http://www.naturalaspirations.com/ )and dialed in the air/fuel for the new intake manifold. Today we returned to Superior Automotive to compare the results. As you can see by the graph, the Pray Ported OEM intake manifold is slightly better below 5,000 RPM, with a significant advantage right at 4,000 RPM. Above 5,000 RPM the MSD is better, posting a gain in peak HP of about 15 HP, but a whopping 33 HP gain at 6,500 RPM. For reference, we baselined this car bone stock on 91 octane pump gas July 31, 2019 at Superior and it made 403 HP and 404 torque. Is it worth $1500 for 15 peak HP? You decide. Pray did the same test a couple of years back and the results are comparable : https://www.camaro6.com/forums/showthread.php?t=494652
Bolt-ons.
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I would say that's a significant difference when shifting at 6600-6700 or so rpms. Stock is done around 5700. Thanks for the post.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
![]() Drives: 2017 Camaro 2SS 50th Anniversary Join Date: Sep 2017
I think it's definitely worth it especially considering you're able to get more power in the higher rpms. People are paying the same amount if not more for kooks and American racing headers and x pipe to roughly make the same 15 peak horsepower. If you decide to do heads and cam there's going to be even more power disparity between manifolds.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
good info. who ported the msd?
Shifts under load
Sounds like cat delete pipes might be comparable to catted longtubes (the only way I'll do).
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#7 |
I am getting E80 at my local pump.
Bolt-ons.
#8 |
wow factory headers.
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Agree with this, try shifting around that rpm zone to get the most out of your improvement. I have an MSD on my SS too, and try to shift in that area.
#10 |
Black lightning
No need to port. Imo. Ur only gonna get maybe 10 extra hp MAX not worth all THAT money to me.. It pulls hard as hell top end regardless its a beast
[ 2021 Camaro ZLE 10 speed
#11 |
super easy to port the MSD, that said there is a seam just before the flange to the head. I would like to fill it and smooth it with something? Two part epoxy? JB weld for plastic? dunno. Anybody done it?
#12 |
perhaps we share a difference of opinion. if one is going to spend the $1k+ on a high performance intake manifold, spending an additional $300? on porting and matching is not only beneficial but also necessary. otherwise, leave the stock stuff on it. i’m not an 85%er. ill do it right or not do it at all.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
nice build and write up and i know the guy that runs natural inspirations mostly a honda/import guy i believe but cool to see him help with some gm stuff also!
#14 |
I used to work with his dad at Harbor City Honda, back in the day. I tuned the car, Chris provided the dyno.
Bolt-ons.
