Old 05-07-2017, 10:52 PM   #43
SaGa
SaGa's Avatar
Drives: 2016 Camaro RS 2LT I4
Originally Posted by Adp2017 View Post
I ordered the ZZP Catted DP and magnaflow catback exhaust last night! This thread makes me think I made the right choice. Now to hurry up and wait...
I would love to see a video to hear this setup if there is anyway you can show me let me know!
SaGa is offline   Reply With Quote
Old 05-08-2017, 12:00 AM   #44
Beast-Y-Blue
Drives: Hyper Blue 2016 Camaro turbo
Page 3 of this thread I have a couple sound clip links... or look me up on IG @gen6turbo
Beast-Y-Blue is offline   Reply With Quote
Old 05-08-2017, 11:39 AM   #45
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
Ill have video I can post tonight, it is from my dyno run. The setup sounds sweet but if you don't want a loud exhaust this isn't for you lol
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq
ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator
Adp2017 is offline   Reply With Quote
Old 05-08-2017, 08:59 PM   #46
Beast-Y-Blue
cant wait to hear your exhaust. you got the catback magnaflow exhaust with the catted ZZP DP right?
Old 05-09-2017, 09:49 AM   #47
Adp2017
Adp2017's Avatar
yes that's right. didn't find time last night again to post.
331 rwhp , 350 rwtq
Old 05-15-2017, 11:43 PM   #48
JP1995
Drives: 2017 2.0T
That sounds awesome! I did the muffler delete and it sounds better than stock but I was thinking about adding the glasspacks without changing the downpipe.
I'm just not ready to change the downpipe yet for fear of causing a check engine light or giving reason for my warranty to be voided.
Do you think the glasspipes will deepen the exhaust with the stock DP or will it be little change?
JP1995 is offline   Reply With Quote
Old 05-16-2017, 03:36 PM   #49
Beast-Y-Blue
to my opinion the muffler delete alone sounded great. so if your not doing the DP yet I'd wait. with the DP it makes all the difference in the world but I think some kind of aftermarket mufflers is needed with the catless DP cause otherwise it is unbarably too loud. I don't know how the glasspack would sound alone. might tone down and clean up the sound but at this point I don't think the muffler delete needs to be tone down as far as im concerned... I actually wanted the muffler delete a bit louder and deeper.
not sure if this helps.
Old 05-17-2017, 04:19 AM   #50
JP1995
Drives: 2017 2.0T
I could not stand it... as much as I liked the Borla I went with the flowmaster American Thunder. Later I may add the DP but for now I am excited about this exhaust!!
For anyone thinking about doing a muffler delete only, I actually liked the sound level and loved the gurgle type noise it makes when you left off the gas. My biggest issue was that at idle or low RPM it lost its " rumble" and was more of a louder steady sound. I have terrible hearing so it could just be me but I feel like this flowmaster or any of the other systems will be a better mix of rumble and volume.
After driving it with a muffler delete for a week I cant wait to see the difference next week with the flowmaster.
By the time I tried a few more mufflers and custom setups I felt like I would be cheaper to just buy the flowmaster axle back. Your input did help Beast-Y-blue. This setup will give me the option to go with your DP later
Old 01-15-2019, 09:09 AM   #51
Arctic_turbo
Colossus_2.0
Arctic_turbo's Avatar
Drives: 2017 Camaro 2.0 LTG turbocharged
Need some advice guys, I got a custom exhaust installed with the zzp catless dp and noticed just too much drone, how can I get a deeper sound and cutting that drone sound? Thank you
Arctic_turbo is offline   Reply With Quote
Old 01-15-2019, 10:00 AM   #52
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Do you have a muffler delete?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 01-15-2019, 10:36 AM   #53
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Look for an exhaust with mufflers or resonators. Borla also makes a mid muffler that may help. I had the same issue. I re-installed my stock muffler but it sounds like shit with the catless DP. Carven Exhaust also makes resonators.
MBRP has built in Hemhotlz resonators.
Mishimoto's Pro Exhaust has resonators.
Holley Catback has a muffler option.
Then you move to the stupid expensive Borla options.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 01-15-2019, 12:38 PM   #54
irobles3680
Drives: 2017 2.0 Camaro LT
SLP loudmouth lol I love mine but has a lot of drone, I don’t mind the drone since I ride a straight pipe motorcycle and use to it
irobles3680 is offline   Reply With Quote
Old 01-15-2019, 12:48 PM   #55
whiskeyfed
Pat
whiskeyfed's Avatar
I had the SLP one. With the catted pipe it was great but the drone with the catless pipe is crazy.
Old 01-15-2019, 01:26 PM   #56
irobles3680
I have same set up catted dp and SLP, I got catted cause I don’t like getting cel
