Old 10-14-2016, 04:00 AM   #43
AndyUK
Drives: 2017 Camaro SS
Originally Posted by DisturbedSS View Post
incorrect
Based on what? Or are you going to keep posting things and deleting them when i respond?
If that is what your installer has told you then get it in writing, because what you posted before is flat out not true, the magnuson warranty makes it very clear that the onus is on you to try to prove that their calibration or hardware failing caused the issue, pretty easy for them to argue that your engine was in an unknown state before their install.
Based on what others have said about getting warranty support on S/C installs I would just assume that its basically worthless as it gives them a lot of wiggle room. The magnuson wording actually makes it clear that if you had an underlying engine problem then their warranty won't cover you, and the S/C install already voids your GM warranty so you would be out of luck either way.
AndyUK is offline   Reply With Quote
Old 10-15-2016, 05:17 AM   #44
cncmotors
Drives: camaro
Originally Posted by JANNETTYRACING View Post
Hello Jay,
There are no provisions in the Magnuson tune or the tuner to account for LT headers and exhaust.
You will need a Custom tune.
Email me directly tedj@jannettyracing.com
Ted.
Oh, okay. That means we do not have to purchase the tuner at the same time. I will shoot you an email then.
Thank you.
Jay
cncmotors is offline   Reply With Quote
Old 10-17-2016, 08:04 AM   #45
JANNETTYRACING
JANNETTYRACING's Avatar
Thank you.
Jay
The SCT tuner will come with the supercharger system and can be also used for custom tunes.
I sent you my custom tune instructions.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
