![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
JANNETTY RACING 16 M6 Magnuson Heartbeat ARH Headers exhaust combo
We just finished and delivered Lesbaer's beautiful Grey 16 M6 camaro.
We installed the Magnuson Heartbeat kit, along with ARH 1 7/8 coated LT headers, high flow cats and x pipe to factory NPP muffler. We had the opportunity to dyno it stock, then with the ARH Headers and exhaust,, then with the Heartbeat on the as delivered tune, then I re-tuned it for final numbers. Stock 418 RWHP 417 RWTQ ARH 438 RWHP 440 RWTQ Heartbeat and ARH 563 RWHP 544 RWTQ Gain of 145 RWHP 127 RWTQ
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
![]() Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
Awesome numbers and awesome work, Ted!!!!
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
#3 | |
How much boost to be able to get these results? Thanks.
FMPG
Drives: 2016 2SS Join Date: Dec 2015
Got back last night after driving the car up to Boston (and pretty much all over the south shore of MA all weekend) and I still have spaghetti legs. It's amazing and I kept it at the stock boost - but remember every car could have slightly different results. While I could push this higher, I'm very, very happy with it right here. It's exactly where this car should be in my opinion. It's still well balanced, and can be civilized and a wolf in sheep's clothing without over-stressing the engine.
The headers make it so loud on track mode (it's sounds very intimidating) and the NPP still works to quiet it down at the push of a button. I let my best friend that I grew up with drive it. He had a hot-rodded IROC when we were kids. As we were going through a tunnel in Boston (enjoying the echo of course) two under-cover staties put their lights on, then pulled up next to us. "Sounds great!" they said and then drove off without even asking for our licenses. Yes, it's really that good - even in 5th and 6th. On my way up there I also happened to run into a C7 Z06. All that I'm going to say is that I'm sure I left at least one person scratching his head. I'm not sure that I could've had a better a day ![]() It was a 3 hour trip up there and we literally drove all over the place until 8pm. Silky smooth, no temp fluctuations, no nothing, except two grown men who's faces hurt from smiling and laughing so much. I drove home for another 3 hours yesterday and commuted into work this morning (1 hr) and it's all good. I also have to say that I was very surprised how well the stock wheels and tires stayed connected. I only have about 1600 miles on them. We did not try launching the car, but hammered it in every gear. You won't lose grip unless you really go nuts in 1st or 2nd, so I'm actually rethinking the need for my planned 20x10, 20x11 wheel upgrade and might not go as wide to save weight...we'll see. HUGE THANK YOU to Ted and his team. They're good, professional people who do what they say they'll do. Listen to the man because he knows what he's doing and he genuinely wants to make you happy. He's also literally the one who's tuning your car and not just a name. In Ted I trust
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge ![]() 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Fantastic review thanks! Please keep the feedback coming.
Standard as delivered pulley 6 PSI with the improved exhaust flow.
#7 | |
Enjoy it.
#8 |
Thank you Ted for the follow up. I appreciate it. Very, very impressive numbers!!
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Wife's 14' IS 250 Join Date: Mar 2014
Wow... Newb question, but what supporting parts would be needed on a stock SS when going the supercharger route??
I would also like to know how much total an upgrade like this would cost, including supercharger, extra supporting parts(if needed), & install? Sent from my iPhone using Tapatalk
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers Last edited by Adrian97c; 05-02-2016 at 10:43 AM. |
#10 | |
This Kit bolts on any Stock 2016 Camaro. Please give me a call 203-753-7223 or email me tedj@jannettyracing.com for a quote for your car. Thank you Ted.
#11 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Ted, what are people doing for fuel management on the 6th gen? What options are available to date?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
#12 | |
We have used Meth injection as a fuel supplement with SC. Most of the big power builds are using some sort of supplemental fuel system in boost. There are cams with larger lobes to run the fuel pump harder. The Z06 pump and injectors can be used I hear but have not done it myself.. Hope this helps.
#13 | |
It does, thank you. I was just curious about the fuel management on the 6th gen. Was also wondering what the stock system could support. But you answered that. Thanks again
#14 |
Drives: 2016 2SS Join Date: Mar 2014
20hp for a 2k exhaust...doesn't seem like a good deal to me
