Old 08-11-2025, 03:33 PM   #477
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The entire site is doing this not just the ZL1 subforum.
Old 08-11-2025, 03:55 PM   #478
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
I have no idea... I hope it's fixed soon...
Yeah I noticed that too and it's showing there are posts but it's not showing which ones have been updated. Outdated forum junk issues probably.
758 HP/ 804 TQ
Old 08-11-2025, 04:10 PM   #479
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
I agree, very irritating...
Old 08-12-2025, 07:43 AM   #480
cajunzl1
Drives: 2018 ZL1
Socal, nice chart on the boost.
Did you have any comparison vs. the 2.5 upper pulley? my guess is 10 or 11lbs?
cajunzl1 is offline   Reply With Quote
Old 08-12-2025, 12:03 PM   #481
SOCAL.M6.ZLE
Hey buddy, I dont... I put a 2.4" pulley on when the blower was ported the first time around... I would assume a similar step down, as it was up.
Old 08-12-2025, 12:06 PM   #482
SOCAL.M6.ZLE
I will also update the chart once finished with tuning, and I can do some more pulls from 2,500 to redline with the new set up... currently only doing street pulls in 3rd gear going up grades in order to keep the top speed low. I'll do a top of 4th pull soon when I can find the right road / time...
Old 08-12-2025, 12:07 PM   #483
cajunzl1
Drives: 2018 ZL1
Thanks
and thanks for everything you do for this forum!!
Old 08-12-2025, 12:32 PM   #484
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
That's the way I do my tuning for the exact same reason. Up a hill in 3rd gear to get it right, then verify on a 4th gear pull in a controlled environment.
Mods being installed-
Old 08-12-2025, 12:41 PM   #485
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Thanks
Second that !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 08-12-2025, 01:27 PM   #486
SOCAL.M6.ZLE
Thanks
You are very welcome! Just doing the little I can to keep up with the heavy hitters on here
Old 08-12-2025, 01:43 PM   #487
SOCAL.M6.ZLE
Great minds think alike
Old 08-12-2025, 05:58 PM   #488
ZLRob
Super Stock
ZLRob's Avatar
I think I've always done my pulls the same way. Up and incline, locked in 4th (automatic), from 40-100. Lately just to ensure fuel pressure integrity all the way through under an extended load I have been doing pulls from 25-100 in 4th under WOT up an incline. That has shown me any and all prevalent issues that may be hiding either in fueling, timing or anything else that I might be blanking out on right now.
758 HP/ 804 TQ
Old 08-12-2025, 11:04 PM   #489
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I drag on the brakes for lower speed pulls, lol
'20 ZL1 Black "Fury"
Old 08-13-2025, 06:29 AM   #490
clg82
Drives: 2020 Camaro ZL1
Are you on stock exhaust Radz, SoCal? Off topic I know lol.
