#463 |
![]() Drives: Turbo 6.2 Join Date: Feb 2019
Pic of log.
top grouping. Blue constant is requested low side @75psi i believe. light blue is actual low side psi. 2nd group down. orange across the top is pedal which is 100% green is actual tps which dips to 44% throughout the pull. it should only dip during the shift and come back to 86% or whatever it is.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 Last edited by Choda; 10-21-2021 at 10:17 AM. |
#464 | |
Moderator
What CEL are you getting? If it's just a nuisance code why not set it to "No Error Reported"? I hear you on the car scene and the tracks closing. Feel like it's been a lame year for this stuff. I'm finally going to the track this upcoming weekend and they close for the season next weekend... so not many chances to get a 9...!
#465 |
dragway 42 is open sat. 3.5 hours away. weather looks good. I just might give it a try.
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
#466 |
As Josh mentioned you might have to disable that code for the fuel system. DSX mentions that it's common to get a p2635 with the AUX setup and that is considered a nuisance code.
#467 |
weather looks bad this weekend. Dragway 42 is open into November so I still have time. My tuner sent me an updated tune to try. Maybe I'll get another pull in with the dragy.
I'll check the engine diag to turn off the code. Will that eliminate the code from the history for inspection?
#468 | |
Moderator
#469 |
Tuner sent me an update. Car pulls hard and no more throttle cut. Everything in the log looks good from my noob eyes. I made the e85 adjustments and CEL changes in prep for going flex/full e85. I'll stick with 93 with the current setup but I'd like to have everything ready for when the time comes.
Broke into the 4s with the dragy 60-130. I'm not going to try again unless it warms up. The tires are spinning around 80 every time and its a handful.
#470 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
I’m not far north of you in Ontario. I must say you got balls making pulls like that in these temperatures. Love your build. Just be safe brother
#471 |
I found a procharger intake with port injection. I really dont want to go into the dual ecu route but know its a possibility. I also think going to direct port meth is a good idea at this level. I still have the OEM plastic intake and it's held 18 psi but I don't want to push it or find the point where the distribution of the triple nozzle before the TB is going to cause issues.
Still fighting inspection CEL permanent and history codes from when I built the motor and fired it without updating the ecu for the lme front cover and dsx aux.
#472 | |
#473 | |
Moderator
#474 | |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
#475 |
yeah that's pretty slick. I'm wondering if I bought a new computer, had it programmed to my vin at the dealer, plugged it in, key on and loaded my current tune ( with all the cam sensors turned off ) it would solve my issue.
#476 |
Moderator
Won’t it have to be installed in the car for them to flash it? The minute you power up with missing hardware that the ECM cannot see…permanent code. Not going to lie, it’s a crappy situation you’re in.
