#29 |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
My TB is port matched to the adaptor which is then port matched to the intake. All three taper as if one.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit Last edited by SSShark; 05-28-2025 at 06:58 PM. |
#30 | |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
You didn't need to RTV or make a custom gasket for your adapter to manifold?
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#31 | |
![]() I retained the o-ring on the intake and the Katech adaptor has an o-ring on the TB side. See photo in post 19
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit Last edited by SSShark; 05-28-2025 at 06:59 PM. |
#32 |
Here's a better shot which would better explain. 103mm in from the TB and tapered down to 93mm into the intake. Nice even flow.
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit |
#33 |
![]() Drives: 2010 camaro Join Date: Dec 2017
thats solid! If i can do it over again with my mods i would have just gone katech 103tb to ported msd maninfold and call it a day. Only flaw is checking the msd bolts backing out after a couple heat cycles. It will make more more power in the long run!
#34 | |
I plan on adding a SC package next year but I wanted to maximize my gains in the meantime.
#35 |
Finally put the car together after getting the snout ported.. had some leak with the gasket, now it sealed well with RTV. felt the car is more smooth and higherf low torq
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband. |
#36 | |
![]() Will be nice to have a before/after for those specific upgrades, too. I'd probably leave the 4.0 pulley for the dyno, just to see what/where gains are had without changing blower speed. And then get my next bump. Tuner says I have enough pump/injector for more boost... it's just not good enough until the LT4 hardware is whooped. LOL
#37 | |
![]() I feel that based on your build, you would benefit greatly by getting that snout ported to match. I haven't put her on the dyno yet, but very curious myself to see the results. What kind of power are currently putting down?
