Old 05-14-2025, 10:30 AM   #1
wang970305
Drives: 2021 Camaro 2SS
Port out LT2 snout to 95mm?
hi guys,
I have FBO set up as showing in my signature. The IM runners were ported by GPI with slight cleaning on the snout. Looking to port out my LT2 snout to true 95mm to match LT5 TB opening just to play with it more. Maybe get bit more hp?
I heard it would not need to be retuned.
Can someone with experiences or tuning knowledge help me verify it?
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
Old 05-14-2025, 04:04 PM   #2
GreyGhost702
Drives: 2019 Camaro 1SS1LE
I'm not a tuner, but I would say it depends on how effective the port job is. If you are removing enough material to move additional air at the throttle body, it could need tune tweaking. Being tuned for a 95mm will leave you pretty close, but increasing the cross sectional potential for air volume at various throttle positions might be just enough to either leave power/throttle response on the table or potentially cause drivability issues. Going from 87mm to a full 95mm port is a decent jump in volume potential. The tune for the throttle body accounts for most of it, but I think adjustment will be needed. Maybe the computer will see it and compensate, I'm not sure.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 05-14-2025, 05:36 PM   #3
wang970305
Thank you for ht input man, yeah, I was mainly tryna see if it is worth to port it out cuz I could potentially have a vacuum issue by eliminating the O-ring without getting any gains
Old 05-15-2025, 08:33 AM   #4
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
my LT2, adaptor and LT5 tb are all port matched to 95mm. You do not have to port beyond the O-ring.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is online now   Reply With Quote
Old 05-15-2025, 09:10 AM   #5
wang970305
This is what it looks like on mine now. The snout is obviously smaller than the 95mm adapter
Old 05-15-2025, 11:00 AM   #6
SSShark
SSShark's Avatar
Here's how mine came out. The opening on my snout is actually 92, so everything matches. Once you open it to 95, I believe that's where you run into problems. Did you port the adaptor?
Old 05-15-2025, 11:53 AM   #7
wang970305
No, ICT has 2 styles of adapter, 95 to 95 and 95to 87. 95 to 95 is what I showed in the picture. I have heard people have to basically port out the whole o-ring groove and seal with RTV. I feel it makes sense to have a 95mm opening snout match 95mm TB. I just dont know if it is worth it or if I would have any drivability issue.
Old 05-15-2025, 12:34 PM   #8
SSShark
SSShark's Avatar
I bought the Katech 95 to 87. That's probably why he was able to better port match. That might be a better option for you.
Old 05-15-2025, 04:23 PM   #9
GreyGhost702
I personally don't feel the juice is worth the squeeze. Standard porting and smoothing out the inlet port to the adapter is as far as I would take it. For a NA build, I wonder if it would even be worth a handful of ponies just in the inlet alone? I doubt it would be worth hogging it all the way out even for a FI build. Are there gains? Sure. Worth the trouble? For the most part, I doubt it.
Old 05-15-2025, 05:07 PM   #10
SSShark
SSShark's Avatar
On the 95 to 87 tb, the 95mm opening faces the tb. The 87mm opening faces the snout. That way you can port the 87mm side to match the 95mm snout. Everything matches nicely.
Old 05-15-2025, 05:29 PM   #11
wang970305
I bought the 95-87 adapter, however, I am curious if it worth to try to port the nwsout to 95mm for more gain?
Old 05-15-2025, 05:34 PM   #12
SSShark
SSShark's Avatar
According to the shop that did my porting and the tuner, it's worth it. We'll find out tomorrow. I drove it for a few minutes yesterday and the throttle response is already hair trigger .
Old 05-15-2025, 08:43 PM   #13
wang970305
did you do the comparison between 87/92 and 95?
Old 05-15-2025, 09:11 PM   #14
SSShark
SSShark's Avatar
No, I installed it yesterday and tuning tomorrow. The only comparison I'll have is between the 87mm LT1 intake and TB, and the 95mm LT2 intake and LT5 TB.
