Old 05-01-2025, 01:46 PM   #29
Laidoffsick
Laidoffsick's Avatar
Drives: Camaro ZL1
I have the CSP 2" LTH (made by Kooks) and went with the Jet Hot 2500 coating. Melt that main wire harness and you'll pay way more than the coating trying to trouble shoot the issue and fix it. Buy once, cry once. Not worth the risk of putting headers on without some kind of coating.
2022 ZL1 Red Hot. Mods: OEM 1LE 19" wheels, PS4S tires 325/305, LED side markers, Rock Guards, 2" CSP Longtube Headers (made by Kooks), Catless, Rotofab Big Gulp, DSX Flex Fuel, Soler Performance LT5 ported throttle body w/ adapter plate, MSD Plug wires, LSA SC Reservoir upgrade, Custom tune, E54 w/91 Octane, 677 rwhp, 714 ft/lb.
Laidoffsick is offline   Reply With Quote
Old 05-01-2025, 07:31 PM   #30
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Are you saying even after relocating the harness you can still burn it? Did you relocate yours?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 05-04-2025, 11:05 AM   #31
2023ZL1RapidBlue
Drives: ZL1, S2000
I'm very interested to know the same question that Dynamical is asking. Did you melt the harness even after getting your headers coated?
2023ZL1RapidBlue is offline   Reply With Quote
Old 05-04-2025, 11:41 AM   #32
IndyZrider
IndyZrider's Avatar
Drives: 21 SHOCK ZL1 M6
No....he's saying coat them so you don't have to worry about it...either way moving the harness is a must imo....
IndyZrider is offline   Reply With Quote
Old 05-05-2025, 07:48 PM   #33
2023ZL1RapidBlue
Drives: ZL1, S2000
I assume you moved thr harness in yours as well?
I'm gonna have to look into this before I drop the car off.
Old 07-08-2025, 12:03 PM   #34
clg82
Drives: 2020 Camaro ZL1
I know this thread is a couple months old, but does anyone have a picture of the wiring harness you guys are referencing? Also how much does it cost to add the coating?
Old 07-08-2025, 12:42 PM   #35
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I got you, bro. Red arrows point to the large harness that I had already heat taped and pushed back toward the strut tower, and also the hard brake line that I heat taped for good measure. The brake line was closer to the header than the wire harness. The harness sits on the frame rail, but tends to push toward the header. Mine was not too bad, so I re-bent it a little and ensured that it was staying put. Some people have put a clip on it, or put it on the other side of the coolant reservoir.
Name:  Screenshot 2025-07-08 133956.jpg
Mods being installed-
Old 07-08-2025, 02:18 PM   #36
clg82
Attachment 1165875
Thanks Rob, appreciate your help!
Old 07-20-2025, 12:10 AM   #37
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Great question on the cost... I paid around $800 to coat my entire system from header to axle but was not happy with the finish / performance, so I decided to wrap mine also. Early testing looks promising, more data to follow...
Would love to know what others have paid for the JetHot...
Old 07-20-2025, 10:36 AM   #38
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
Just got mine (ARH) done.
$545 (2k coating)
$240 2-way frieght w/insurance
Camaro SS - (almost) FBO/E85: Tuned by Snackbar Tuning/21st Century Muscle Cars
tortilla-flats is offline   Reply With Quote
Old 07-21-2025, 07:56 AM   #39
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
For your normal bolt on street car, uncoated QUALITY stainless steel headers is a non issue. If you start making 900+ wheel HP and race the car at the track...you want to start considering having headers coated.
Out of all of the headers we've installed, only a handful were coated. Never had an issue on any of the cars over many years, coated or uncoated.
GM Gen V Calibrator
Old 07-21-2025, 09:53 AM   #40
JSH
JSH's Avatar
Drives: '20 ZLE
My wrap is effective, but I've never been comfortable with the appearance, so I'm sending them to Jet Hot for a Classic Polish coating
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 07-21-2025, 10:13 AM   #41
clg82
This tracks with what the shop said that will be doing my Kooks headers. Said out of all of the headers they've installed they've never had a car return because it burned up that wiring harness. Or any harness for that matter. Knowing how I am though, I do plan on moving those wiring looms away from the headers and adding some extra heat tape. Better safe than sorry.
Old 07-21-2025, 11:19 AM   #42
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I don't think Jason (ZL1Atlanta) has his monster diameter headers coated for what it's worth.
