Old 04-23-2025, 08:51 PM   #1
2023ZL1RapidBlue
Drives: ZL1, S2000
Kooks header without coating?
Hey there.
Question for those that got Kooks headers installed.
I'm contemplating to get one of RPM's ZL1 packages which include the Kooks short system with High flow cats and midpipes.
Question is, they stated the headers are not coated. For those that have them, did you notice an increase in temperature? I'm afraid of extreme temps that may melt things specially with a IC reservoir in that general area.
RPM stated that in their experience, coated isn't needed, that these headers actually do not get as hot as the factory cast manifolds, which I get that. But, will the heat produced be dangerous around parts?
I did state to them what about road course high rpm driving and they still said, temps will be fine. Anyone have any experience with these Kooks headers uncoated?
2023ZL1RapidBlue is offline   Reply With Quote
Old 04-24-2025, 01:37 AM   #2
TristinErdman
Drives: honda
The Kooks are made of stainless steel (Solitaired), which dissipates heat better than cast iron, so they tend to retain less heat over time.
TristinErdman is offline   Reply With Quote
Old 04-24-2025, 03:26 AM   #3
Z OH 6
Drives: 2024 CT5-V Blackwing
They aren't going to melt anything but under hood temps will likely be higher because headers are thinner than cast iron manifolds. The stock manifolds also have heat shields on them.
Old 04-24-2025, 04:48 AM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
+1
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 04-24-2025, 05:47 AM   #5
Z OH 6
I had mine coated for this exact reason. Underhood temps were lower than the stock manifolds when coated with Jet Hot Extreme 2500.
Old 04-24-2025, 08:22 AM   #6
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
+1 for a high temp coating...
Old 04-24-2025, 08:47 AM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I would never run uncoated headers on this platform. Giant bundle of wires 4” away on the passenger side.
Old 04-24-2025, 11:06 AM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yeah +1 to that.
Came here to say protect the pass side harness... or Very_Bad_Things(TM) will happen.
Gunkk is online now   Reply With Quote
Old 04-24-2025, 11:09 AM   #9
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
I have been running uncoated Kooks on my 2017 SS for almost 4 years. Never had any problems.
But I did make sure that the wiring harness on the passenger side was secured as far away from the headers as they could be as well as wrap them with some heat insulation just in case.
As long as you have clearance of everything around the headers, they will be fine.
All that being said, coating the headers is never a bad thing.
Spaceme1117 is offline   Reply With Quote
Old 04-24-2025, 01:42 PM   #10
2023ZL1RapidBlue
Drives: ZL1, S2000
Thanks for the info, much appreciated!
Old 04-24-2025, 01:44 PM   #11
2023ZL1RapidBlue
Drives: ZL1, S2000
Thanks for the info. That was my argument to them but they did say Kooks actually run cooler than stock..Underwood temps.Dont wanna be the one to find out that they run hotter.
Old 04-24-2025, 01:47 PM   #12
2023ZL1RapidBlue
Drives: ZL1, S2000
Thank you for the info on the coating. I'll look into it.
I used to.use header wrap on previous vehicles many years ago, but it turns into ugly rags eventually and retained moisture.
Old 04-24-2025, 01:48 PM   #13
2023ZL1RapidBlue
Drives: ZL1, S2000
Thanks for making me aware of the wire bundle.
Old 04-24-2025, 01:50 PM   #14
2023ZL1RapidBlue
Drives: ZL1, S2000
Yeah +1 to that.
Thank you for the warning, much appreciated. I haven't been under the hood since winter, but I'm gonna find that giant bundle of wires
