Old 06-13-2024, 12:35 PM   #29
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Megahurtz View Post
test the DSX port kit on the Whipple 3.0 build
What will the DSX port kit be comprised of?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-13-2024, 02:51 PM   #30
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by race24x View Post
Hi there I am looking to do some mods to my ZL1 and wondering if anyone has done these and what their results were.
1. Big Gulp
2. Kong Xport
3. 2.3 pulley
4. 103MM TB
5. Custom Tune
Stock manifolds stock cats but some Cat back that is pretty loud
So, less air restriction could be 5-10 hp, X-port 50 hp, more blower rpm 5-10, TB 10 hp, tune 20-30 hp, maybe you'll reach 100.
2020 ZL1LE A10.
Old 06-13-2024, 04:13 PM   #31
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
The DSX Controller itself is what I meant. The car already has Whipple specific port plates(currently plugged) and rails, and then we have LS3 injectors that we will use. We are waiting on the availability of the DSX port controller.
GM Gen V Calibrator
Old 06-13-2024, 05:36 PM   #32
JSH
JSH's Avatar
Drives: '20 ZLE
So if I were to go port injection I would need the DSX controller, injectors (size ?) mounted in the 2650's bungs and fuel lines.. Wouldn't I need a separate hpfp fuel pump?
2020 ZL1LE A10.
Old 06-13-2024, 06:38 PM   #33
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Port injection adds to the existing Direct Injection system. Too High PSI Reflex controller or DSX's controller is required to drive the port injectors. Moving some of the fueling to the port system will reduce the DI side load.
You would need a low side that can handle the fuel pressure. Whatever lines needed to plum the low side injectors, Port plates for the 2650 with fuel rails and then LS3 style injectors.
DSX is making it so you don't need to tune anything but the ECU. Too High PSI you need to tune the ECU and the Reflex Controller.
GM Gen V Calibrator
Old 06-13-2024, 06:52 PM   #34
JSH
JSH's Avatar
Drives: '20 ZLE
I've got DSX low side and OEM high side now. Sounds like I would need to plan to add additional low side capacity
2020 ZL1LE A10.
Old 06-13-2024, 07:00 PM   #35
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Depends on the fuel you want to run. If going full E85 from 100octane race gas you will likely need at minimum the largest DSX low side pump available. There is also a Katech dual 400 intake that would definitely suffice.
We have a 3.0 Whipple, 416 built motor ZL1 that we haven't start tuning yet. It has the largest DSX aux kit only as the low side, stock lt4 hpfp, XDI 30% DI injectors and LS3 port injectors. I don't know how far the DSX aux will take us until we start tuning. Previously the car was in the upper 800's on a custom port LT4 blower and a lot of meth and E80.
GM Gen V Calibrator
Old 06-13-2024, 07:58 PM   #36
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Why would you run plates with the Whipple 3.0, it’s already got injector bosses cast into the runners…? Simply drill those out and drop the injectors in. Couple that with the very high Whipple blower height, those plates would make that cowl situation even worse… I’m assuming you’re running the subframe spacers Whipple provides?
Old 06-13-2024, 08:53 PM   #37
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Sorry I mean the runners. They had to be removed and sent to get machined for the port injectors. I had the stock blower stuck in my head while working on something else.
We have the BMR mounts that drop the engine the same as the spacers do. But it still wont clear the stock hood. Even the spacers as well wasn't enough. It needs about 1.5 inches of extra clearance. The BMR drops about half and inch and the spacers another half an inch. We are going to cut the hood and install a carbon fiber insert on the underside of the hood to clear the Whipple. I'll know more once that comes in.
GM Gen V Calibrator
Old 06-13-2024, 09:01 PM   #38
JSH
JSH's Avatar
Drives: '20 ZLE
I don't know which lowside I have now. It runs at 80 psi. Which LS do you have? https://dsxtuning.com/collections/aux-fuel-filters
2020 ZL1LE A10.
Old 06-13-2024, 09:14 PM   #39
JSH
JSH's Avatar
Drives: '20 ZLE
Apologies to the OP. I suppose we can setup a PI/ fueling thread.
2020 ZL1LE A10.
Old 06-14-2024, 06:25 AM   #40
Joshinator99
Moderator
Ok, gotcha on the runners. Seemed crazy to add plates lol
Interesting on the hood clearance..no issues on my stock SS hood. I’m running just the subframe spacers and clear the cowl by maybe 1/2-3/4”. I recently bought the BMR mounts as well but haven’t installed them…would be great to get rid of the spacers.
Old 06-14-2024, 07:50 AM   #41
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
The 320 lph pump option with the DSX Aux Kit. I'm not sure it will be enough fuel but we're going to see.
We reached out to Whipple and they stated the fitment on the SS vs the ZL1 is different and the ZL1 required a hood insert or another means to add clearance for the hood(more than the provided spacers). Now is this accurate for all ZL1's? I don't know, this is the first Whipple 3.0 for us so its a bit of a discovery along the way.
GM Gen V Calibrator
Old 06-14-2024, 08:07 AM   #42
JSH
JSH's Avatar
Drives: '20 ZLE
My Eddie also requires the removal of hood matl and an insert if looking pretty is a necessity, which it isn't.
I assume you're running Eth. How much power are you hoping for?
2020 ZL1LE A10.
