Old 01-11-2025, 07:39 AM   #29
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
If you're stock heads and/or stock cam on an LT1, don't bother with the 95mm TB. Just get a ported 87mm, like the Soler 91mm Eff unit. Even with an unported LT2 TB, put the ported 87mm on it.
If you do a cam, port the LT2 manifold and have it ported for a 95mm TB. Then get the ported 95mm TB from Soler, I think its called the 100mm Eff unit. You could also just do an unported 95mm but the ported unit has an advantage above the stock rev limiter which you typically exceed when you put a cam in the car.
If you do heads and cam, get an MSD intake manifold and a 103mm TB.
The NA cars don't pick up power with oversized throttle bodies like LT4's do. In fact, they typically lose low-mid range torque if your throttle body is too large for the air flow the engine can use.
GM Gen V Calibrator
Old 01-11-2025, 09:17 AM   #30
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Thank you Megahurtz. I was slowly leaning in that direction after reading all threads. I have stock heads and cam along with mods in my signature. So non ported LT2 along with a ported 87mm TB. My question is why port the 87mm TB?
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is online now   Reply With Quote
Old 01-11-2025, 01:19 PM   #31
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
You get just a little bit more airflow near redline which pairs well with the LT2 intake manifold.
GM Gen V Calibrator
Old 01-11-2025, 01:26 PM   #32
SSShark
SSShark's Avatar
Got it, thanks brother
Old 01-14-2025, 08:52 AM   #33
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
If you have to pick between a non ported LT5, or ported stock 87, just get the LT5. Porting isn't cheap and can be problematic to tune, where the LT5 is very affordable and tuners know it well. Plus you can still have your stock 87 if you ever need it, or wanted to sell it to recoup some cost.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
RideWithDanger is offline   Reply With Quote
Old 01-14-2025, 09:52 AM   #34
SSShark
SSShark's Avatar
I've been speaking with a very reputable local tuner about this. He does nothing but LS and LT cars and has assured me to definitely go ahead with the ported LT2 along with the ported LT5. He's done several of them with positive results. I'm going to give it a shot. Worst case scenario, I can always go back to the stock intake and TB.
Old 01-16-2025, 11:53 AM   #35
RideWithDanger
Drives: 23 2SS 1LE
I went with ported LT2 IM and stock LT5 TB, but as long as your tuner is comfortable with it and you are okay spending the money for the minimal gain, then port the LT5 and enjoy!
Old 01-16-2025, 01:03 PM   #36
SSShark
SSShark's Avatar
Old 01-16-2025, 01:47 PM   #37
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
I don't know why I feel like you were talking directly to me what that statement. I know you said don't do nothing else but I don't see that here.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 01-17-2025, 07:30 AM   #38
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
I was speaking generally for NA setups. Stock heads/cam NA LT1's don't need the airflow from a 95mm TB. The gains come more from the LT2 intake manifold vs the LT1 manifold. Then porting the stock TB is the cheaper option and you won't gain anything by going to a 95mm TB.
Why do you think I was talking about you? lol
GM Gen V Calibrator
Old 01-17-2025, 09:08 AM   #39
WiggyB
WiggyB's Avatar
You're good I was just being sarcastic. The car runs like a dream since the last update you provided. I just be combing the threads and looking at little stuff that could be done. Then when the weather breaks I go for a ride and forget all about it. As we all know the itch never goes away so you're always looking.
Old 01-17-2025, 01:37 PM   #40
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
my car is N/A un opened bolt on 95mm TB/ MSD see my times below drag radials and E80 remote tune from GPI. drive 50 miles to the track and back great street manners, Car pulls like a freight Train up top!
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 01-17-2025, 09:50 PM   #41
vince3
Drives: 2022 Vivid Orange LT1-M6
This is a legit question, if stock heads/cam Na doesn’t benefit from the TB, then why do all the 500 plus rwhp and the fastest bolt on cars run big throttle bodies ? Is it something that only benefits high rams or are you saying it’s just little gains for the money? I can also link the posts in here with non header cars running MSDs and 103s putting down 480 plus rwhp.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 01-17-2025, 10:03 PM   #42
vince3
https://www.camaro6.com/forums/showthread.php?t=587847
https://www.camaro6.com/forums/showthread.php?t=577766
https://www.camaro6.com/forums/showthread.php?t=543424
https://youtu.be/j5iR4i4kEIc?si=N66IYx31PcGFcaCh
https://www.camaro6.com/forums/showthread.php?t=535959
Here’s the ones I’m thinking of. You just don’t see LT2 intakes with ported 87s hitting these numbers. 2 of them don’t even have headers.
But I guess they can just mess with dynos to show any numbers.
