Old 03-23-2022, 11:38 AM   #29
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Originally Posted by SteveV View Post
Thanks. It is definitely on my purchase list now.
Hey Steve, if you're bored April 2 meet me at the cruise-in at Mojos in Garner and you can check out my Rotofab. Probably be there around 2:00 or so.
https://piedmontccc.org/event/mojos-grill-cruise-in-4/
Old 03-23-2022, 11:51 AM   #30
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Same, I want more whine and think it is worth the price. Will likely add headers later too, so it will play a performance role eventually.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 03-23-2022, 01:46 PM   #31
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Will do...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 03-23-2022, 02:43 PM   #32
KamZL1
KamZL1's Avatar
Drives: Z06
I think it's been proven multiple times to add power guys, saying it does absolutely nothing is just not factual. Now to what degree is debatable but how many have you seen on here post gains over stock with just rb or rb/tb combo?
KamZL1 is offline   Reply With Quote
Old 03-23-2022, 03:45 PM   #33
hawk02
Coupe Newbie
hawk02's Avatar
For those that may remember, here is the initial dynograph Roto-Fab posted comparing their ZL1 intake vs stock on the factory tune.
It does show HP gains from about 5000 rpm up. However, it also shows a slight loss of torque in the mid-range rpms.
The loss of torque is what concerned me at the time because that’s right where your engine spends most of the time driving on the street.
Old 03-23-2022, 03:54 PM   #34
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Sorry not buying it. When I first bought my car and put the roto fab on I did before and after being totally stock to a roto fab and a full 3” cat back.
Results were within 4-5hp of each run.
Also since when does a stock lt4 make 11lbs or 11.99 pounds of boost ?
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 03-23-2022, 04:16 PM   #35
hawk02
Coupe Newbie
hawk02's Avatar
Yea, 11 lbs of boost is a bit high. As long as it was measured the same for each run it’s all relative.
Roto-Fab’s 5th gen ZL1 intake increased boost about a pound over stock. It’s not surprising that their 6th gen intake does the same.
I really think torque management in the tune is a factor in the loss of torque. To me, this more or less confirms you’re not going to get much gain from a after market intake without a tune.
Old 03-23-2022, 06:29 PM   #36
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Originally Posted by xplct View Post
What is the sound tube delete option? What's the purpose to that? I know CAI don't really do much, but they look cool as hell.
ZL1s don’t have a sound tube.
