Old 08-16-2021, 09:14 AM   #29
FoundNemo
Drives: 2019 ZL1
Excellent progress
Cheers! Of note, this is also with the knock sensitivity back to completely stock values. CSP Headers are truly no joke and do not need desensitization of the sensors for false knock from header noise, which is a major boon in my opinion. My buddy is thrilled.
We tested the theory by upping running the MS109 blend (5 gallons) with 93 and with stock sensitivities for knock to see if any false knock came on. Not a hint of it.
Last step is to run through the blended gas and see how the car handles 23.5 degrees of timing with the headers on straight 93 in the heat. If it starts pulling timing for real knock, we'll back her down to 22-22.5 and set her in place for the long haul.
FoundNemo is offline   Reply With Quote
Old 08-16-2021, 10:42 AM   #30
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by FoundNemo View Post
Here is the pull in 3rd at WOT. Zero knock now with the Cyl #1 static retard zero'd out. No more rev limiter hits with it bumped up 100rpms for max now too.
Start your pull at 3rd,4th I like using 4th. Start at 2000rpm, slowly go into the throttle then lay the hammer down until 6500. You’ll be able to go through all cylinder air masses and rpms to check for knock.
In a safe place of course.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-16-2021, 11:18 AM   #31
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Should be making a pull in at least 5th with a A10. Not enough load on the engine in the lower gears.
Old 08-16-2021, 11:21 AM   #32
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is it the thickness of the tubes that have a bearing on that? One thing I noticed with a set of Kooks I had (1 7/8" for a truck) was the tubes seemed thinner than I would've expected. I realize thicker tubes mean smaller ID, but I'd sacrifice whatever flow/scavenging that might reduce (I doubt anything...) for being able to use stock sensitivity, as exaggerated as it might be.
Just make sure not to rape your ignition tables. Let that MAT-table work for you.
That's what I did. I don't know where my head was at, but I was trying from a dig on street tires and it was so difficult to maintain any traction, which meant I wasn't getting any low-RPM data. I finally took my head out, and put the DRs on, and started pulling in 3rd (not a lot of places around me to really ring-him-out space-wise; and a lot of patrols around me). That made such a big difference. I was worried about the TMA for shifts, but I found once I got most everything in-line, that the shifts worked-out just fine. Good suggestion. It's easy to forget some of the simpler stuff sometimes
'20 ZL1 Black "Fury"
Old 08-16-2021, 12:38 PM   #33
FoundNemo
Drives: 2019 ZL1
Will do next to check.
Old 08-16-2021, 12:41 PM   #34
FoundNemo
Drives: 2019 ZL1
The pipes clear the engine mounts and stuff better than Kooks which can vibrate against engine mounts causing false knock.
Old 08-16-2021, 12:42 PM   #35
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Sure you can. An incline, it’s better then telling him to go WOT in at least 5th on the street. 5th is a buck twenty
It’s not perfect by any means but it’s the best data without a dyno.
Old 08-16-2021, 01:20 PM   #36
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
OH. I hadn't learned it was more fitment than anything. That makes sense then. No wonder.
Yeah - Not around these parts, LOL.
Old 08-16-2021, 06:15 PM   #37
KingLT1
KingLT1's Avatar
Where in my post did I say to go 120 on the street?
Old 08-16-2021, 08:10 PM   #38
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
"Should be making a pull in at least 5th with a A10. Not enough load on the engine in the lower gears."
Hes not on a dyno.
Old 08-16-2021, 09:01 PM   #39
KingLT1
KingLT1's Avatar
I was thinking the track or air strip. I am not opposed to making a street pull either if you have a good spot. I realize that some don't. I'll leave that up for Nemo to figure out.
Old 08-17-2021, 03:16 AM   #40
FoundNemo
Drives: 2019 ZL1
No room locally for that kind of speed comfortably or safely. Will use a steep hill to work it harder.
Old 08-17-2021, 08:25 AM   #41
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
He's got a point though. The longer you can stay in the cells (under steady state), the better the data is. That's all he's trying to say. I've actually used lower gears and modulated my brakes to try to do something similar. Typically - I make 4-5 hits and just make sure I'm using cells where I get a minimum of 20-25 hits. If you watch how the cells change, at idle, for example, you'll see they move around until the ECM finds it's happy place.
Old 08-17-2021, 08:53 AM   #42
KingLT1
KingLT1's Avatar
