Old 02-17-2021, 07:45 AM   #29
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
Once a JMS FuelMax is installed, does it require a retune?
7LitreC5 is offline   Reply With Quote
Old 02-17-2021, 07:54 AM   #30
JANNETTYRACING
JANNETTYRACING's Avatar
That depends if someone was trying to cover up loss of fuel pressure in the tune.
If so the car will get richer up top after adding it.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 02-17-2021, 08:45 AM   #31
7LitreC5
Ted.
That makes perfect sense. Thanks.
Old 02-17-2021, 08:46 PM   #32
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
That would be awesome! I'm still waiting on other parts as well as new crimpers so I'm in no hurry. If you have them I'd really appreciate it, if you don't thanks for the offer anyways
Evansa22,
Just checked and I do have some extras. I have the seals, female and male pins. PM me with a mailing address and I’ll drop them in the mail for you tomorrow.
Trevor
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 02-18-2021, 07:38 AM   #33
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Originally Posted by TMS View Post
Evansa22,
Trevor
Your awesome! Info sent
Old 03-17-2021, 07:05 PM   #34
20Bluezl1
So im bring this thread back as I have installed my JMS but I was going to switch out the fuse and my cover isn't mark FSCM Fuel pump. I read it's F35 that needs to be changed but not sure. My F35 has a 20amp fuse and marked FSCM V6.
Old 03-18-2021, 06:40 AM   #35
tomster
RedLine
Drives: 2022 ZL1 1LE
Sub for reference
tomster is offline   Reply With Quote
Old 03-18-2021, 06:47 AM   #36
ZLE dude
Drives: '18 ZL1 1LE
If LiqTenExp hasn't answered by the time I get home this afternoon I'll pop the trunk open and take a look at which one I changed. I honestly can't remember.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 03-18-2021, 07:26 AM   #37
20Bluezl1
Old 03-18-2021, 08:27 AM   #38
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Sorry not able to check car this week. I can't imagine both of those should be populated. I would have done the V8 one unless I blindly followed instructions. It should be very easy to tell which is the correct one... pull it one at a time and see which one causes the JMS to not light up! That is the right one to replace LOL
Old 03-18-2021, 08:56 AM   #39
7LitreC5
Is the FCSM circuit (wire gauge, etc.) of sufficient size to be able to handle a max amperage increase from 20A to 30A?
Old 03-18-2021, 05:05 PM   #40
ZLE dude
Drives: '18 ZL1 1LE
Originally Posted by 20Bluezl1 View Post
Mine was F35. My 2018 ZLE didn’t list a v6 or v8 FSCM on my fuse box lid. See pic.
Old 03-18-2021, 05:29 PM   #41
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
My 2020 ZL1 has the V8 FSCM in F46, already a 30amp fuse
Oddly, F35 has a 20amp fuse installed. Wonder what it's used for
There's a 10amp in F31 (power folding top), mine's a coupe, so maybe they make them all the same so assy is easier
Old 03-18-2021, 05:54 PM   #42
20Bluezl1
Yea but F35 is 20 amp and it also says FSCM
tms, xxx zl1
