#29 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I found a store that has the "old" PF64 oil filters. Mine is brand new, think I'm better getting it over the Wix in case there's every a warranty issue.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#30 |
2020 Shadow Gray 2SS
If you are the least bit concerned about warranty, I would stick with the AC Delco PF64 filter...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Glad to help, fellas
"KEEP THE FAITH"-Fbodfather |
#32 |
Shifts under load
I will. I can already hear them now blaming the Wix filter like they did my TS headers when I told them I could hear rear end noise on decel Went back to the same dealershiip and asked for a different tech/team and they replaced my rear diff at 45k miles. I've been a service advisor at new car dealers for 22 years. Too many "technicians" think like that.
#33 |
Shifts under load
Just scored 3 of the “old” PF64’s at a Walmart near me. Visually inspected them too. Headed to another one.
#34 |
![]() Drives: 2017 ZL1 Join Date: Apr 2020
I'm using the new PF64 with no concerns. I also put in the m1 esp 0 W 40 oil Thanks for the write up op
#35 |
![]() Drives: 2018 ZL1 Convertible M6 Join Date: Nov 2019
Not to throw another variable into the equation, but I ordered a PF64 from Amazon last week and got this, a 3rd GM part number.... 12706595.
At first I thought this was a knockoff because of the look of the box but a brief Google search says this is AC Delco's new packaging design. Thoughts? |
#36 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Saw this, appears to address a gasket issue. I saw something (somewhere) regarding the gasket falling off and a slight leak.
https://gmserviceinsights.com/new-ac...ed-performance
#37 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Also, while it's true that carbon buildup on intake valves is an issue with DI engines, I don't see how it could end up in the oil. The valves don't have exposure to the oil (hopefully!). Besides, the whole point of the problem is that the carbon never gets washed off the valves in a DI engine because there is no gasoline going past the valve to act as a constant solvent. The amount of carbon deposited on the valves is the same as non-DI engines, but less of it is shed from the valve, not more. GM is clear on the reason for the change in bypass pressure: the tighter clearances in the newer engines requires a filter that is less easily bypassed so that the oil is better filtered. I don't see any mystery here.
Matt Miller
2020 SS 1LE |
#38 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
If you know the history of the 'Elite Engineering' user, you'd automatically add him to your 'ban list'. He routinely trolls all auto enthusiast boards screaming about the horrors of the GDI platform and the only solution is his catch can.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#39 | |
His incessant trolling made me buy a Mishimoto Catch Can instead of his... Someone that has to push their product THAT hard raises a LOT of red flags for me...
#40 | ||
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
#41 |
Oh, okay! Sorry to give the troll more air time, then. Thanks for filling me in.
Matt Miller
2020 SS 1LE |
#42 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
