Old 02-02-2020, 07:08 PM   #29
Gbrownzl1
Drives: Zl1
Originally Posted by CDFF View Post
No one uses Motul anymore?
I still do and I've had 0 issues. Used it in my gt500 and zle.
Gbrownzl1 is offline   Reply With Quote
Old 02-02-2020, 09:03 PM   #30
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Interesting
I must be out of date. I’m still using ATE Amber. No issues to date
Using stock pads, so it takes firm pedal pressure.
The car has a combination of Z28 and 6th Gen front brake cooling
What are y’all using for brake cooling and pads
Old 02-02-2020, 10:26 PM   #31
cdb95z28
cdb95z28's Avatar
Originally Posted by h018871 View Post
Interesting
I used ATE amber and Super Blue in my '95 Z28 back in 2007-08. I sold the car in 2009 and it had the Super Blue in it. Sold it to a local guy. He then sold it 2 years ago to a older fella in West Virginia. He called me last year when I was coming home from a trip to Tennessee and NC, So I stopped to see the car. He let me drive it and the brakes felt amazing. And it still had the ATE Super Blue in it. From 10 years ago!
"KEEP THE FAITH"-Fbodfather
Old 02-03-2020, 11:13 AM   #32
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i used motul 660 my shop told me that or castrol srf is what they use but the castrol is alot more $$
Old 02-04-2020, 11:13 PM   #33
Mize442
Mize442's Avatar
Drives: Current driver AMC emlin X 5ltr.
Hey guys. I have a new set of CF brake lines to put on shorty. I am looking for the best brake fluid to use.
I use my car 97% of the time for street use and the rest for Autocross and hopefully this year once or twice at the track. Novice class.
I'm hoping there is a great fluid that gives better to great brake feel and will last more than a season or 2 before needing to be changed. Also should I invest in new pads at the same time? Car has 12k
Thanks
Mize442 is offline   Reply With Quote
Old 02-05-2020, 10:32 AM   #34
PROMETHEUS
PROMETHEUS's Avatar
Brembo HTC64 or Castrol SRF. Although you will get a lot of opinions about others and just as good or better. My suggestion is to start with one and go from there, but at the very minimum Dot 4
Old 02-05-2020, 12:46 PM   #35
Crawdog450
Drives: 2018 ZL1 1LE
COMPRESS AWAY
Originally Posted by DANACO View Post
This is all very confusing to me regarding what is discussed here as “compressibility”, by definition, liquids are non compressible, period. Perhaps different fluids affect the seals differently, and perhaps, different formulas feel different when heated, but cold or warm, non should feel any different unless viscosity is a factor.
Liquids are compressible. For most peoples use and general purpose as well as 8th grade science class they aren't, but they are. Hydraulic systems reach well over 3,000 psi in today's world. All liquids are not equal either. Each have comprehensibility rates. Water, JP8, and Hydraulic fluid all have different compress rates and limits. Impacted greatly based on temperature. Just a thought.
As per brake fluid. I ran StopTech brake fluid in a Viper and this ol heavy Camaro. It was fantastic under some pretty hard braking at AutoClub Speedway in Fontana. Mixed with Carbotech X24 brake pads..... It was fantastic. No issues last July in the heat for 25 mins straight.
Crawdog450 is offline   Reply With Quote
Old 02-06-2020, 10:35 AM   #36
NITEMER
NITEMER's Avatar
Drives: 2017 Camaro ZL1
h018871 what combo brake cooling are you using? Z28/ZL1 combo? Sounds interesting!
NITEMER is offline   Reply With Quote
Old 02-06-2020, 11:42 AM   #37
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Z28 ducts and inner fenders with 6th Gen front lower control arms and deflectors. Also using the 6th Gen heat shields behind the rotors.
From my build thread:
Deflector on pg 11, post 141
Backing plate pg 11, post 143
Duct work pg 8, post 106
Hope that helps
Old 02-17-2020, 05:40 AM   #38
Blackshirt56
Blackshirt56's Avatar
Drives: 2017 Chevy Camaro 1LE
Prospeed RS683 is a revolutionary racing brake fluid. Not only does it boast an extremely high 583° F dry boiling point and a very high wet boiling point of 394° F, but an innovative new manufacturing process actually makes this fluid more incompressible than other fluids! Meets DOT 4 specifications and is compatible with all DOT 3, DOT 4, and DOT 5.1 (non-silicone) fluids. 500ml (16.9 oz) bottles.
2017 1SS 1LE - Nightfall Grey Metallic
Texas Speed 1 7/8 Headers & 3” X-Pipe
Borla ATAK Axel Back
Roto Fab CAI
E85 & Tune
10% tints all around
Blackshirt56 is offline   Reply With Quote
Old 03-15-2020, 07:56 PM   #39
s.hammer
Drives: 2015 Z/28
Best place to find HTC64?
s.hammer is offline   Reply With Quote
Old 03-16-2020, 10:38 AM   #40
PROMETHEUS
PROMETHEUS's Avatar
https://www.hrpworld.com/bre-htc64-b...ter-bottl.html $29.95 plus shipping
https://www.ebay.com/itm/Brembo-HTC-...UAAOSw8thZl5GU
$32, free shipping
Old 05-05-2020, 09:17 PM   #41
Cleancoupe
Drives: 18 ZL1 1LE
I’m about to order some brake fluid for my car and was going to go with either SRF or HTC64, but that Prospeed RS683 looks like a great option. Especially for the price
Cleancoupe is offline   Reply With Quote
Old 05-05-2020, 11:16 PM   #42
Biscuit.fr
Drives: Red hot ZL1 A10 2017
I use motul 660 dot4
No issues
Daily drive
Race 2-3 times a year.
How often do you have to drain or check?
Min once a year, after each track event?
Biscuit.fr is offline   Reply With Quote
