![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Brake Fluid
I am sure this has been talked to death....however. I came across an article comparing Tier 1 Racing Brake Fluids
https://thebuildjournal.com/tech-gui...view-analysis/ On the face of the article I was impressed with Torque RT700 in the area of Compressibility. I have been used Castrol SRF for the past couple of years, but I am not immune to making a change "if it is better". Does anyone have any experience with Torque RT700 and Castrol SRF and give their impression of both. Thanks in advance, Tony |
In doing a little more research, it appears Torque RT700 is no longer available. I guess some type of internal strife, caused the company to go belly up. Oh well!
![]() Drives: 2018 ZL1 1LE Join Date: May 2019
Brembo HTC64
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
![]() Drives: '19 ZL1 1LE Join Date: Feb 2019
![]() Drives: Really Fast Join Date: Aug 2017
I don’t understand the love of Castrol SRF. It’s got a very high wet boiling point 519F but a really low dry boiling point 590F. One of the lowest of ester based fluids. Endless RF650 never gets any love but I believe the numbers show better performance with dry and wet boiling point. 622F/424F. If you change your fluid before track days your only worry should be dry boiling point. Endless surpassed Castrol a long time ago. F1 teams almost exclusively use Endless.
THIS SPACE FOR RENT
Agreed Larrio. I was going to give Brembo HTC64T a try next year, when I do my flush for the 20 track season. I came across the aforementioned article and noticed the Torque RT700. The author made a reference that Torque was hard to find. Of course, now I know why. I did see that as well about Endless was used by F1.
#7 |
![]() Drives: Camaro ZL1 A10 Join Date: Feb 2018
I heard the SRF lasts longer between changes and what I've experienced at least compared to common Motul but not the ones mentioned above.
#8 |
![]() Drives: Zl1 1le Join Date: Apr 2018
Remember the moment you expose brake fluid to the atmosphere it becomes "wet". Therefore for most real world use - the wet B.P. is a better indicator than the dry.
#9 |
![]() Drives: 2018 ZL1 1LE Join Date: Apr 2018
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid |
#10 |
![]() Drives: Hopefully 6th gen Camaro Join Date: May 2015
Has anybody used Bosch ESI6-32N Brake Fluid (Direct Replacement for DOT 3, DOT 4, and DOT 5.1)?
#11 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
Changing to HTC this week. Agree with comments here. SRF has been meh.
#12 |
![]() Drives: 2017 Red Hot ZL1 Join Date: May 2015
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I just switched from (fresh)SRF to the HTC64T, definitely a better pedal feel!
"KEEP THE FAITH"-Fbodfather |
#14 |
This is all very confusing to me regarding what is discussed here as “compressibility”, by definition, liquids are non compressible, period. Perhaps different fluids affect the seals differently, and perhaps, different formulas feel different when heated, but cold or warm, non should feel any different unless viscosity is a factor.
