#29 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Thanks guys, great info and I appreciate the feedback.
My order is in! |
#30 |
![]() Drives: 2018 NFG SS 1LE Join Date: May 2018
If this truly tightens up the rear end then I NEED this.
I read through the install instructions on the BMR site, and of course the comments above, and it makes it sound almost too easy to install... Can I do it with one jack in my own garage? I'm concerned, maybe even a tad confused, about dropping/raising the rear cradle to access the bushings. Any hints/pointers from those that did DIY would very welcome before I place an order. Cheers, Alex |
#31 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#33 |
Current:
#34 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The Camaro team emulated the rubber bushed subframes of past BMW //M cars. It takes a perceptible edge off the transient response that gives the car a less hectic personality and reduced induced snap oversteer. It's all in the tuning calibration process. Given we're on an enthusiast website, most of us probably want hardcore, but the bulk of the buyers will undoubtedly find the total package perfectly amazing.
#35 |
![]() ![]() Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
Really curious if this kit will also fit on the ATS-V, which is a very similar chassis. Since I own both, I will be tempted to review the possibilities.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
#36 | |
Going from my M3 to the SS 1LE, I was able to tell a difference in the first quick transition maneuver I did. I hope they hard mount all the performance/track models in the next Gen.
Current:
#37 |
![]() Drives: 2018 ZL1 coupe Join Date: Nov 2018
The instability in the rear is noticable enough in routine driving that I'm surprised it made it to production with the soft bushings.
#38 | |
![]() ![]() ![]() Drives: A10 LT4 Join Date: Aug 2016
Have you seen any improvement with the fishtailing problems from a roll?? |
#39 |
![]() Drives: 2017 Camero ZL1 Join Date: Nov 2015
I had never done a road course prior but the car didn't wiggle at all Sunday. I did notice a few 6th gens in front of me had the mentioned wiggle when losing traction especially in a straightline however mine did not. I don't have any video unfortunately. I did two 20 minute open sessions at MSR Cresson with the local Camaro group. The first session I didn't do so well but the second session I improved significantly. The 555 G2s were screeching plenty around turns but they held up better than I anticipated. Next time I get the chance to run out there will provide a detailed review.
2017 ZL1 A10
Dyno/Quarter Mile/Dragy 9.71@141.2 MPH so far. 2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold. |
#40 |
![]() Drives: 2017 Camaro ZL1 Join Date: Aug 2018
You're not kidding... that's why I can't stand driving in touring mode. With the amount of sway from the roads, I thought at first my alignment was off.
#41 |
I was actually clapping because I couldn't believe you said anything positive about this mod and didn't talk down on it because it doesn't remove the last 1mm of deflection.
Idk what would be fun about me going to the track and kicking ass while you are doing "real" driving on the street |
#42 |
![]() Drives: 2021 Wild Cherry ZL1 1LE, A10 Join Date: Jun 2013
This kit is very easy to install. I was actually disappointed with how easy it was as I am a true gear head and love working on cars. I did it in a garage on Jack Stands no problem.
I can say that it tightens up the rear end and also helps eliminate some of the wheel hop that I have experienced. |
