Old 11-24-2018, 08:33 PM   #29
squish72
Drives: 2016 2SS 8AT
Originally Posted by Gasoline_Farts View Post
I was looking to do this with a Normally closed switch like this:
O'plaza ®Dc 12V 10A Relay RF Wireless Remote Control Receiver Momentary Switch (12V 1 Channel) https://www.amazon.com/dp/B00W8V4KQ4..._1DY9BbS6SDXQT
The same as what’s in the pic in this thread, but I notice it’s only rated for 10amps
But the standard fuse for
Npp is 15 amps,
Will this cause problems?
I used a 10 amp one from Amazon and it works fine. I opened it up and resoldered it so it was normally closed. Synced it to my homelink buttons and it's been working for months. Was able to hide it under the fuse box
squish72 is offline   Reply With Quote
Old 12-17-2018, 01:52 PM   #30
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
Can you explain what you re-solder to make the switch be normally closed?
trohde78 is offline   Reply With Quote
Old 07-08-2019, 02:51 PM   #31
raisingarizona
Drives: Acura MDX
Originally Posted by MGD View Post
Look at the big red circle, polarity on a fuse.
The big red circle highlights a yellow fuse adapter. The top fuse provides power to the remote control gizmo. The bottom fuse completes the original circuit. Nothing out of sorts there.
raisingarizona is offline   Reply With Quote
Old 07-08-2019, 11:00 PM   #32
forzasteve
forzasteve's Avatar
Drives: Love any sports cars
Well, having a masters in electronic engineering for the last 42 years, + stands for positive 12VDC and - stands for 0VDC aka Ground.
The + and - on the fuse contacts represent the hot side and the cold side of the fuse contacts in the fuse block. If you remove the fuse and then use a voltmeter and measure the voltage from the hot side to vehicle ground, you should get nominal +12v. If you measure the cold side to vehicle ground you get 0 v. If the fuse position is switched to the ignition, you will need to turn on the ignition to get those readings. If the fuse position is not switched, then you should get those readings at all times.
When you are using a fuse tap to add an additional circuit, the bottom fuse location in the fuse tap is for the original circuit. The top fuse is for your additional circuit. In this situation, it is important to orient the fuse tap correctly ... otherwise, your additional circuit will not be fuse-protected. Your original circuit will not be affected, but the add-on circuit will be.
The term, polarity, may be somewhat confusing, but this is what is meant with respect to using a fuse tap. The fuse itself does not have polarity. Only the contacts in the fuse box.
forzasteve is offline   Reply With Quote
Old 07-09-2019, 10:36 AM   #33
Here is my 'fuse tap for dummies (like me)' mock-up version. Actually, with the fuse tap inserted the wrong way, the additional circuit will still be protected, but will load the original fuse along with the original car component that the fuse was for, so it's more prone to overload and being blown.
Old 04-07-2020, 04:27 PM   #34
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
OLD THREAD ALERT
Originally Posted by Ricco View Post
At best, this switches the valves from 'Auto' to Open. I'm still looking for a system that offers full manual control of the valves - Like I want to force them closed, as well as force them open.
Has anyone found a way to close the valves on startup without using the Infotainment Screen?
Looking at the circuit, it appears as though a modulated signal from the chassis control module closes the NPP valves rather than just a 12v or ground being switched..........
Old 09-11-2022, 09:23 PM   #35
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Great question. I’d love to start in stealth mode whenever the kids are sleeping. A switch would work perfectly.
Dabjbr is offline   Reply With Quote
Old 10-06-2022, 07:36 PM   #36
pondo
Drives: '23 SS 1LE
I put the exhaust in stealth when I pull into my neighborhood every evening.
“Scientists dream about doing great things. Engineers do them.” -James A Michener
'23 SS 1LE Rapid Blue
18’ SS 1LE Hyper Blue - sold
pondo is offline   Reply With Quote
Old 04-14-2023, 02:51 PM   #37
jollymon
Drives: 23 SS 1LE M6,15 1LS M6,26 CT4VBW M6
So for those that chose to wire it to a in-cabin switch, where'd you run the wires and mount the switch?
I'm going this path... but before I go figure out from scratch, wanna learn from others that already been there.
2015 SIM 1LS M6 - fun DD commute car
2023 RRT 2SS 1LE M6 w/PDR - FUN!!
jollymon is offline   Reply With Quote
