Old 07-03-2018, 12:02 PM   #1
forzasteve
forzasteve's Avatar
Drives: Love any sports cars
DIY - NPP Exhaust Controller
To those of you interested, here is how to make your own exhaust controller. I am showing you two methods ...
  1. Use a manual switch. Very easy, very inexpensive. Total cost would be less than $10 plus your time to get the parts, run the wires and install the switch inside the cabin.
  2. Use a remote control relay. Easier than doing the switch. Total cost about $20 plus your time.
I have developed the Forza Exhaust Controller that is the best quality you can buy. The advantage of purchasing the controller is that you get it tried and proven and it has more options. The Forza Controller, Mild2Wild and any other controller that is available uses the same overall concept. But, that plug aside, I wanted to share with you all here that if you are a bit handy with DIY projects, this is an easy mod.
Look at the attachments. One illustrates the electrical schematic for each option (manual switch or remote relay) and the other illustrates how to modify one of the power taps to accommodate the circuit for the flapper valves.
Parts Required for Manual Switch Option
  • Manual SPST Switch (On - Off) ... price varies ... $3
  • Power Tap (aka add-a-fuse) ... about $3
  • 0.110 x 0.032 male tab disconnect ... about $0.25
  • 18 AWG wire ... about $2
Parts Required for Remote Relay Option
  • Single channel remote control relay ... about $10
  • Two taps ... about $6 total
Note: Getting the male tab disconnect might be problematic when you only need a single piece. As an alternative, you can also strip the end of the wire about 3/16", twist the copper conductors tightly and then tin the end with solder. This will make the end rigid. You can then insert the rigid end into the power tap where the male disconnect would go. Secure the wire to the main wire of the power tap with a bit of electrical tape or shrink wrap tubing.
Also, the illustrations indicate ATO Fuses and power tap. The ATO fuses are for Aston Martin. Camaro Gen5 uses Mini fuses (aka ATM). The Camaro Gen6 uses Micro2 series fuses.
Regards,
Steve
forzasteve is offline   Reply With Quote
Old 07-18-2018, 11:53 AM   #2
gomerboat
Drives: 2017 ZL1
Hey Steve,
Do you know where to buy the 0.110 x 0.032 male tab disconnects? I find them on Amazon, but it's a pack of 100 for $16. I'm local to you as well if you know of any places in the valley. Fry's maybe?
gomerboat is offline   Reply With Quote
Old 07-18-2018, 09:34 PM   #3
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Can you please explain what exactly is being controlled when this switch is on or off?
17rsvert is offline   Reply With Quote
Old 07-19-2018, 01:15 AM   #4
squish72
Drives: 2016 2SS 8AT
I built a remote relay for my npp. It's super simple to do. Best part is I use the garage door opener buttons to switch it on and off not the crappy controllers it comes with
squish72 is offline   Reply With Quote
Old 07-19-2018, 12:31 PM   #5
FdeleonZ28
Drives: 2016 camaro ss convertible
Will this work with non npp cars switching to npp?
FdeleonZ28 is offline   Reply With Quote
Old 07-26-2018, 06:53 AM   #6
jeffm5690
jeffm5690's Avatar
Drives: 2023 2SS 1LE
I’m guessing that’s is a big no...
2024 2SS 1LE Hyper Blue
Front/Rear Dashcam (Blackvue)
2018 2LT/RS Hyper Blue
Cosmetics - Bow tie
2010 2LT/RS IBM
K&N Aircharger
MRT V2.0 Exhaust
Trifecta Tune
Soon to be added:
Elite Catch Can
Iceolater
Vmaxx Ported TB
Cosmetics - Rally Flags, Door Sillplates
Electronics - Escort Hardwired
jeffm5690 is offline   Reply With Quote
Old 08-04-2018, 06:34 AM   #7
FdeleonZ28
yea i noticed its tied to the fuse box..
Old 08-16-2018, 02:00 AM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
https://www.amazon.com/dp/B00LMICSIQ...d_w=JmBLh&th=1 and this https://www.amazon.com/Lumision-SHIP...fuse+tap&psc=1 is what you get for $80 from mild2wild
Old 08-16-2018, 07:36 AM   #9
24v
Drives: 2018 SS
Can't you just change the setting on the infotainment to achieve the same thing? Track = open, Stealth = closed? Or is Track not open all the time?
24v is offline   Reply With Quote
Old 08-16-2018, 08:05 AM   #10
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
Track is not open 100% of the time.
trohde78 is offline   Reply With Quote
Old 08-17-2018, 08:57 AM   #11
MGD
MGD's Avatar
Drives: 16 Camaro SS
Short
What are you trying to do? I have never in my life seen a fuse connected to 12VDC on one side and ground on the other. As soon it's plugged in, it blows.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 08-17-2018, 09:01 AM   #12
trohde78
trohde78's Avatar
I'm not seeing any fuse that's grounded. The only thing grounded in the schematic is the relay.
Old 08-17-2018, 09:18 AM   #13
MGD
MGD's Avatar
Look at the big red circle, polarity on a fuse.
Old 08-17-2018, 09:26 AM   #14
trohde78
trohde78's Avatar
What does polarity have to do with a ground?
