Old 09-15-2017, 12:11 PM   #29
TrackClub
TrackClub's Avatar
Got it and thx! I am sooo tempted...lol!
Old 09-15-2017, 01:00 PM   #30
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Originally Posted by Provoste View Post
18x10 et 25 x 4 is my current setup, they work great and fit perfect with a 5mm spacer up front.
If I was buying another set- I'd get 18x10.5 et22 square.
Those would poke out back and the front? 18x10 are flush from what I have seen?
WhiteNight is offline   Reply With Quote
Old 09-15-2017, 01:05 PM   #31
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Yep, and yep. Push front and rear 9.3mm further out.
Provoste is offline   Reply With Quote
Old 09-15-2017, 09:50 PM   #32
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
That s not bad. Camber should fix that. You still need a spacer in the front?
Old 09-15-2017, 10:27 PM   #33
Provoste
Provoste's Avatar
Yes, same as 18x10 et25, 5mm spacer on front axle.
Old 09-16-2017, 12:24 AM   #34
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Ah. Ok. Thanks for your help.
Old 09-17-2017, 02:20 PM   #35
SPORTBIKES
SPORTBIKES's Avatar
Drives: 1967 Firemaro / 2017 2SS
I went for the 19s and NT-01s. Put 305s on the rear and this is what I got. Seems like the poke may be too much, especially since the Supercar 3s (20s) had none at the top.
Might be bad offset?
Think I should try these?
Mike Dee
SoCal USA
2017 Camaro 2SS
2015 Corvette Z06/Z07
1975 Supercharged Corvette
1967 Firemaro Show Car - For Sale
SPORTBIKES is offline   Reply With Quote
Old 09-17-2017, 02:50 PM   #36
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
Here's mine with 19x10, +25 with 285's. I think that poke would be about right with a 305.
Edit: well that didn't work....
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 09-17-2017, 03:07 PM   #37
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
What is the rear camber? Offsets?
glamcem is offline   Reply With Quote
Old 09-17-2017, 03:12 PM   #38
LSmith353
LSmith353's Avatar
In attempt not to exceed my Photobucket limit, pics of mine are in this thread, post #10 I think.
http://www.camaro6.com/forums/showthread.php?t=506885
Old 09-17-2017, 04:40 PM   #39
SPORTBIKES
SPORTBIKES's Avatar
Rear is a 19x11
Alignment is stock at this time
Offet - They are said to be 43mm in rear
Mike Dee
SoCal USA
2017 Camaro 2SS
Old 09-17-2017, 04:59 PM   #40
LSmith353
LSmith353's Avatar
My bad. Based on your other posts, I thought you had bought Apex. Ignore my replies........
Old 09-18-2017, 01:13 AM   #41
glamcem
glamcem's Avatar
Rear is a 19x11
hmm they didn't look like +43mm offset to me, my OEM 1LE wheels looked more flush with the same offset. I have 19x11" with +25mm offset (325 tires) and they don't look too different to me
some pictures of that can be found here, for the reference
http://www.camaro6.com/forums/showpo...&postcount=121
Old 09-18-2017, 01:21 AM   #42
SPORTBIKES
SPORTBIKES's Avatar
How are you doing with the 325? Have you had the on the track? They do look similar to these 305s with this cut I have. My guess is that the wheel has different measurements then the MRRR, but when they cut them, they used the same offset. These were the first time to be fitted to the Camaro.
Mike Dee
SoCal USA
2017 Camaro 2SS
