Old 12-08-2016, 10:17 AM   #29
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Originally Posted by ChicagoTommy View Post
I guess I just don't understand the attraction to a gizmo that just sends throttle voltage faster. All you have to do is press the pedal harder and the same effect is achieved and you still have a couple hundo extra in your pocket!
Yes, so let's spend $200-$300 on a failure prone electronic box to do it instead of pushing the gas pedal harder. End sarcasm. These things are so pointless. I still can't find a single reason to consider this product. It doesn't even make the car any faster!
Those two posts no matter how I read them seem to say he has an issue with the product.
Originally Posted by Corner carver View Post
Thats to bad, it may have been a little heated at times, but you guys brought up and discussed relevant topics; as well as offered different view points on like subjects...found it entertaining as well as informative and helpful
Former ATS guy some are good guys others still have the prius smug where they think they know everything there is about a car because they had the same engine before.
Don't worry, I'll still be here discussing things and spreading knowledge. It will be much easier without that dude following me around with a chip on his shoulder.
"Engages super secret you can see me mode" To bad you had good knowledge just always took a one sided approach towards everything we've had enough of those on Camaro5.com that when I see it happening again I just can't resist.
Old 12-08-2016, 10:23 AM   #30
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
Today, 10:17 AM
Remove user from ignore list
Evil-Bee-NH This message is hidden because Evil-Bee-NH is on your ignore list.
Best day ever!
ChicagoTommy is offline   Reply With Quote
Old 12-08-2016, 10:24 AM   #31
Evil-Bee-NH
603 Camaros
Today, 10:17 AM
Best day ever!
I bet
Old 12-28-2016, 09:47 AM   #32
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Where do you keep the display block for the Vitesse TC? it looks like it kind of just hangs out on the side of the seat. Looking to buy one in the next couple weeks, but this is abstaining me. To clarify, the piece that reads out "SP 0-9", where do you put it? does it fit anywhere?
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 12-29-2016, 08:01 AM   #33
whiskeyfed
Pat
whiskeyfed's Avatar
Originally Posted by oemtech View Post
I have VTC installed in my Corvette primarily for testing. I mounted the box to the steerin column bracket under the dash with some 3M taple. I mount the display box to lower part of the dash panel panel with 3M tape and routed the cable along the bottom of the dash. If make it permanent I will mount it in the ash tray and route the line accordingly.
So far I have no issues and using SP4 it works pretty much as advertised. Install took about 15 mins...v But, it took this old fart 20 mins to get the dam pedal out as there was no way to release the clip via the foot well in the Corvette unless your arms are 8' long and your 20 years old.
Thanks! I think I'm going to order one in the next few weeks.
Old 12-29-2016, 08:06 AM   #34
Evil-Bee-NH
603 Camaros
Pretty much what oemtech said it works as advertised bit to install your gonna hafta contort your body some.
Old 12-29-2016, 08:07 AM   #35
whiskeyfed
Pat
whiskeyfed's Avatar
Well I guess ill have to hit the gym again!
