Old 03-28-2017, 03:38 PM   #29
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
Originally Posted by Chevy71 View Post
Are you sure that's correct? Why would GM have an option that had the engine spinning so much faster than the rest of the driveline? That's really hard on the clutch, synchronizer, and Tranny? It just levels off the fuel at 6,500 on mine as well. No extra fuel is being burnt off and it's doing nothing to keep all those moving parts in sync. It slams into gear in mine. I've tried it three times now, and it's nothing like these guys are explaining.
No lift shifting doesn't change the way the car shifts, it just doesn't require you to lift off the gas. The car is essentially lifting off the gas for you.
It is no harsher than a normal high rpm shift.....you are still disengaging and engaging the clutch like you normally would. As such, the synchros operate the exact same. If you are worried about trans and synchro wear then don't rev up past 5k...
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 03-28-2017, 03:50 PM   #30
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
you are basically racing your car if you are doing no-lift shifting... hell yeah, it is hard on everything
crazydmc is offline   Reply With Quote
Old 03-28-2017, 04:30 PM   #31
Sub
Sub's Avatar
Drives: 2017 ZL1
We dont need launch mode on for this to work, right? Its capable of NLS all the time?
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 03-28-2017, 06:28 PM   #32
Chevy71
Drives: 2016 2SS
I think part of my problem was I did it getting on the highway and shifted before the top of the rpm line.. so it went all the way up to 6,500 then I let the clutch out and it slammed pretty hard on the entire drive line. I think I just need to come to terms with, I'm going to break sh!t and then I will fix it. I may be babying the thing too much. Maybe it can handle more abuse than I give it credit for too.
Chevy71 is offline   Reply With Quote
Old 03-28-2017, 06:44 PM   #33
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Correct.
Old 03-28-2017, 10:51 PM   #34
TJay74
Actually NLS is easier on the driveline than the traditional on/off/on throttle along with the clutch operation. When doing NLS the ECM cuts power and timing to lessen the strain on the driveline.
Old 03-28-2017, 11:26 PM   #35
Chevy71
Drives: 2016 2SS
Sure makes a heck of a slam and jerk haha.
Old 03-29-2017, 01:53 AM   #36
gippy87
Drives: 2016 2ss
as far as im concerned my car does not have nls and if it does its broken lol.
I installed nls in my turbo vette and it was great. Worked exactly as expected. The camaro just pegs redline when i clutch in. There is nothing smooth about it.
gippy87 is offline   Reply With Quote
Old 03-29-2017, 08:13 AM   #37
Franko07
Drives: 17 white 1LE
I'm pretty sure your right. Unless there is another way to activate it. It should drop below redline upon clutch engagement. It sounds like everyone is using rev limit to shift and I won't be doing that.
Franko07 is offline   Reply With Quote
Old 03-29-2017, 12:51 PM   #38
Fraxum
Fraxum's Avatar
I defintely had NLS on my 5th gen ZL1, it was smooth, but did not improve my times. On my CA6 SS this does not feel the same for me. I will lift a little.
Old 03-29-2017, 02:13 PM   #39
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
wonder if this theory is applied to F/I vehicles. My assumption is yes, but you now have a different tune, and forced air...? anyone with boost wanna try it?
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 03-29-2017, 02:32 PM   #40
Ian SS
Ian SS's Avatar
If you can't get it to work you aren't doing it right, simple as that. If it jerks and slams, you're dumping the clutch.
Tuning the car or running F/I doesn't affect the NLS. It has a separate window in HP Tuners that is unaffected by fuel maps. You can adjust RPM and TPS activation windows but otherwise I can't see how a tune or boost would affect it.
SLO 1SS - sold
1SS MRC NPP 6MT
Old 03-29-2017, 03:41 PM   #41
Stryfe
Make America Fast Again
Stryfe's Avatar
Drives: 2016 HBM 1SS - M6
Same. I have tried it in all drive modes, launch mode activated, etc etc etc...it just pegs redline. I've powershifted 1st to 2nd but it just feels like a normal powershift. I get no "factory NLS" sensation at all.
Just feels like a normal old powershift to me. And I don't hear this "pop" in the exhaust from the fuel cut, which just makes me believe more-so that it doesn't work.
Someone needs to make a video about this!
This video here doesn't sound like NLS to me. It sounds like powershifting in any other car...
Stryfe is offline   Reply With Quote
Old 03-29-2017, 04:32 PM   #42
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Member Slick3 made this video...he used NLS. Now, granted he has headers (so his pops a lot), but you can clearly hear the pop noises on the shifts. It won't be quite as noticeable from inside, but you should still hear a pretty loud pop/pops when using NLS correctly from the fuel dump. Fuel in hot exhaust = weird noises.
http://vid1224.photobucket.com/album...ps0o43mqu3.mp4
