#29 |
Drives: 2016 2SS Join Date: Mar 2014
#30 |
![]() ![]() ![]() ![]() Drives: CAMARO Join Date: Jan 2017
really sucks what happened...
hopping just relocating the wire harness i can fit 305/35.. |
#31 |
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
This is an old thread there are several people running 305/35/r20 in the rear now. Ask around. I am going to be running 305/35/r20 in the rear and found out need to relocate wiring harness and pull liner in where the harness used to be and they will clear.
#32 |
"Lohla"
315s will fit in the rear with a 6mm spacer. I'm sure the 305 would also.
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
#33 |
![]() Drives: Camaro RS 2LT Join Date: Feb 2020
What tires did you run for the 295/35/20? That’s what I want to run but don’t want to worry about rubbing. Thanks
#34 |
![]() Drives: 2016 Camaro 2SS Join Date: Oct 2021
I'm having the same problem
#35 |
You can apply the same solution
