#29 |
![]() Drives: 2017 1ss Join Date: Jan 2017
to the O.P. or anyone else who may know this ... I dont have any questions of the wiring itself that much I get . But what I am having some confusion with is the LC6/LC7 . In this set up the O.P. clearly states that he used 2 of the 3 inputs on the LC unit but is using all 3 of the outputs .Does it self correct to a 3 channel with only 2 inputs ? it has no switch that does it .
I am contemplating on doing a somewhat similar set up using a 5 channel amp . amp the factory fronts (at least for a while ) , rear channel to a pair of 6 3/4 in the deck lid . and a single sub in the trunk . |
#30 | |
![]() Drives: 2016 Garnet Red 1SS Join Date: Feb 2011
#31 |
Also guys. The company who's first name is sub and last name is thump has a harness now allowing you to not have to cut any wires.
#32 |
![]() Drives: 2016 Camaro V6 2LT RS Fully Loaded Join Date: Sep 2015
He's had that for months now but couldn't wait for the Bose one any longer so just cut the wires. Enough was enough. Waited a year.
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15 My 2LT Review/Pictures/Mustang Comparison My 2016 Camaro Bose Subwoofer Install 2016 Camaro V6 Stock to Borla Atak Exhaust Sound 2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak |
#33 |
![]() Drives: 94 z28 and 2017 1ss Join Date: Feb 2017
where are you guys getting the remote power on signal for the amp?
#34 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
Most modern amps have a signal sensing feature so a remote power wire isn't needed.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
#35 |
#36 |
You may have an issue if you don't connect a remote wire (at least I had an issue). Refer here if you're curious about it at all. http://www.camaro6.com/forums/showthread.php?t=474059
#37 |
![]() ![]() Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
Ok. Looking for a switched 12volt source to turn my Audio Control LC2i on. I thought maybe there is a spot in the box in the upper right corner of the trunk well location that I could tap in to on my 1SS. I know the 2SS has the wireless charger to tap into but my 1SS does not. Just thought I would ask before I start probing around.
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer |
#38 |
Think I used the wireless charging fuse. Just read the box cover and choose whatever common sense says turns on only when the vehicle is turned on or unlocked or opened. That should work.
#39 |
Will look tomorrow. Yes the 2LT has the fuse for the wireless charger unlike my 1SS.
#40 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
Does the 1SS have the active noise cancelling and if so, how did you deal with it?
#41 |
#42 |
Not sure but I assume so. I unplugged it from the start but will try plugging it back in to see. Here is what the harness looks like so I would say yes but we will see.
