Old 02-09-2016, 12:35 PM   #29
132SSLE
Drives: 2016 1LT Hyper Blue RS
Originally Posted by Ricardo@Phastek View Post
SOON!!
I have been calling all the manufacturers we deal with every couple of weeks to stay on top of the waiting game. I keep getting told soon.
You should add me to some sort of list so AS soon as you can order me some parts I can buy them from you!
Also I see you have the GM performance exhaust listed have you heard it installed? is it worth it?
132SSLE is offline   Reply With Quote
Old 02-10-2016, 07:15 AM   #30
b4z
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT
241 hp is a terrible number for a 335 hp motor.
b4z is offline   Reply With Quote
Old 02-10-2016, 08:36 AM   #31
Ricardo@Phastek
Ricardo@Phastek's Avatar
Drives: the boss nuts....
Send a message via AIM to Ricardo@Phastek Send a message via Yahoo to Ricardo@Phastek
I have not heard the GM exhaust or seen it other then pictures. I could not tell you if its worth it or not.
Believe me we were as surprised as you to see the numbers so low. We were hoping to see in the range of 260-270.
Ricardo@Phastek is offline   Reply With Quote
Old 02-10-2016, 01:12 PM   #32
Goblue1313
Drives: F350
Isn't the drivetrain loss on the SS around 15%? The V8 is dropping to 400-405 on the dyno I believe. A 50-55hp loss. This V6 lost 94hp?!! That's around 28% drivetrain loss. Am I figuring that correct? The gearing between the LT and the SS is close so surprised there is that big of a difference in loss.
Goblue1313 is offline   Reply With Quote
Old 02-10-2016, 02:24 PM   #33
Shadowsong
Drives: 2014 Mustang
I'm sure a lot of it has to do with not dynoing in the 1:1 gear, and hitting the speed limiter before they could hit redline. I'm sure the car is probably making closer to 270ish at the wheels.
Shadowsong is offline   Reply With Quote
Old 03-12-2016, 07:25 AM   #34
freddyD
Drives: 2020 rally green rs
yeah those numbers seem low-but my 16v6 is alot faster than my 14.
freddyD is offline   Reply With Quote
Old 09-26-2016, 07:20 AM   #35
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS
That number does seem low. I just had a dyno day this past weekend and my 2016 v6 automatic with NPP dyno'd at 277rwhp.
Interestingly enough, exactly the same rwhp as my 2014 Camaro v6 *6spd manual*
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2016 Camaro 1LT A8 - "Elmo"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 09-26-2016, 12:11 PM   #36
keysersoze
keysersoze's Avatar
Drives: 16 Camaro
well this car is around 300 pounds lighter and has almost no bump in power from GEN5 so I would expect the same RWHP.
keysersoze is offline   Reply With Quote
Old 09-26-2016, 06:07 PM   #37
Rsblueblood
Kywildcats
Rsblueblood's Avatar
Drives: 2020 2SS shock and steel (shocker)
Yea Holley Performance had mine they said the dyno hit
271.17 HP
237.35 LB.FT Torque
Rsblueblood is offline   Reply With Quote
Old 09-27-2016, 09:18 AM   #38
bdar66
Drives: 2016 camaro lt2 rs
271.17 HP
237.35 LB.FT Torque
m6? and was that at the limiter in the 1:1 gear? or was the limiter removed?
bdar66 is offline   Reply With Quote
Old 09-27-2016, 09:24 PM   #39
Rsblueblood
Kywildcats
Sorry took me a while to answer back , that is a A8 and to answer you're second part I don't know I wasn't there sorry.
Old 09-27-2016, 11:08 PM   #40
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
0-60 and quarter mile seems to be fairly obvious that the dyno testing is being hampered by top end speed at telling what peak hp is.
But more importantly it's telling us that peak horsepower / torque is not as important as people would like us to think it is.
What's important is the avg hp and torque for the speeds (power band) you see in actual real life use of the vehicle. And it seems definitive that where it actually matters (less than 160mph) ...the lgx is quite the beast compared to the lfx and in past motors (be them v8's or not) before it.
Old 10-02-2016, 10:43 AM   #41
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Coming from a 2011 V6 LLT I can say the motors are awesome the 270hp range seems more logical those with run-flats have the limiters set at 155-158MPH those running A/S from factory I think are still around 128MPH on the limiter. They are clearly set for safety factors in mind. My 2017 LTG just put down some crazy numbers on the dyno yesterday on a dyno that had 5th Gen numbers consistent with everyone elses. We had a mostly stock V8 with an Intake was around 364RWHP. A few cammed and tuned ones running 462 and 471RWHP.
Old 10-04-2016, 03:39 PM   #42
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
I don't know, for 241hp I was keeping up with a 15 SS pretty well on the freeway one day...
12blkgrayRS is offline   Reply With Quote
camaro, camaro dyno, camaro lgx, dynojet, phastek
