#267 | ||
Petro-sexual
What I do hear at this time is generally under deceleration, and only on choppy/checked asphalt patches. I'm not getting chunking/clunking going over expansion joints or things like that so far. It's definitely not a constant rattle or anything all the time. I know the cradle bushings will transmit more of that noise, but it doesn't seem as bad as I thought it would be at this point. It's more than I wanted, but I also admit what I wanted was not realistic. So far - the rear seems more planted. I haven't had a lot of rips on it yet, though, so I won't deem that conclusive. I need to get the MTs back on to compare. My tuning is blurring some of my observations, too, so I have a lot to polish before I'd make a definitive declaration about my thoughts. My initial impressions, though, are fairly positive.
#268 |
![]() Drives: 2019 Camaro Zl1 Join Date: Apr 2016
Well had the tramlining issue, took to dealership. Low and behold the thrust angle was off and rear toe on both tires was off as well. They got everything in spec again. No issues after leaving the dealership. Made the car feel solid again under hard acceleration.
Letty 2016 2SS 6m Black (sold)
Sura 2016 Z06 3LZ 6m Black (sold) Talia 2019 ZL1 6m Black Bullets always have the right of way..... |
#269 |
![]() Drives: 2018 Zl1 Camaro Join Date: Jan 2022
One would think these "small" alignment issues that only effect this car ... something else is going on. Don't believe alignment is the issues everyone is having. Every car on the road would have it, not just this one.
#270 | |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
I’ll wait…not many! Alignment is a factor, but the cradle bushings and overall soft bushings everywhere else is really the culprit. Mine is straight as an arrow now after unloading the entire BMR catalog on it and getting a good alignment.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
#271 | |
Solution is in the track settings (double click traction control button to open)
Nope didn't buy into that, its a setting be it may suspension setting and or eLSD and finally proved it tonight, totally happy with the car now. Today I watched a video of someone showing double clicking on the traction control button to open up the track settings, you have wet, dry, sport 1, sport 2 and lastly track (then you must click select). Wow what a difference now, no more rear end wiggling / step out back and forth under heavy load. Spent a while tonight driving on the same flat roads back and forth switching between sport & track, then used these Track/Race settings and selecting them. I'm beyond impressed, wish I knew about it prior. While its stiffer suspension, I don't think I'll ever drive in another mode again. IMHO this proves its not the suspension from factory being the limiting factory, yet just sets in either the shock valving and or eLSD. Hopefully someone see things that has been fighting this condition since I hated that feeling. �� Last edited by brad65ford; 01-28-2022 at 07:18 AM. |
#272 | |
![]() Drives: 2019 Zl1 Join Date: Aug 2016
Scary and embarrassing! I will give what you say a try. It never made sense to me that you will need to spend more money,(aftermarket) parts,and time to fix a problem that shouldn't be a problem on a car thats priced as these are! man I cant wait to find out that you are correct! That makes total sense!
#273 | |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
#274 |
#275 | |
Thanks |
#276 |
if you have rear movement and you haven't done the cradle lock out don't waste your time doing an alignment first. Do the cradle kit then get alignment.
#277 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
#278 |
Whats involved in the cradle lockout kit? Is this a do it yourself kit? Same kit for ZLE?
#279 |
D3RPZILLA
ZLE has solid bushing and does not need the lockout kit.
Sent from my SM-G998U using Tapatalk
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy YouTube Playlists: Performance Mods | Show Mods | Other Mods ![]() |
#280 |
