Old 03-19-2018, 03:47 PM   #1
Tampabucs4
Tampabucs4's Avatar
Drives: 2018 blue ZL1
Left to right under full throttle 2018 zl1
Has anyone zl1 felt like it’s floating left to right when flooring at high speeds say 50+?
Tampabucs4 is offline   Reply With Quote
Old 03-19-2018, 04:46 PM   #2
Boosted4life
Drives: 2018 ZL1 A10
Yes I've noticed that as well. Not sure what it is
Boosted4life is offline   Reply With Quote
Old 03-19-2018, 04:49 PM   #3
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
I have not, what tires are you running?
Mcmillion is offline   Reply With Quote
Old 03-19-2018, 04:49 PM   #4
Tampabucs4
Tampabucs4's Avatar
I was wondering if it’s all the air vent and channnels in front of the car. But get up round hundred gets little nerve racking
Old 03-19-2018, 04:50 PM   #5
Tampabucs4
Tampabucs4's Avatar
I’m running 305”s in front and 325 in back. Hancooks in front and mickey Thompson s/s In back
Old 03-19-2018, 04:53 PM   #6
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Having mis-matched tread/sidewall mis-matched front-back can contribute to the car walking on some surfaces. Even some matched treads will walk with grooves in the road surface.
ninetres is offline   Reply With Quote
Old 03-19-2018, 04:55 PM   #7
Tampabucs4
Tampabucs4's Avatar
I mean I’ve had drag radials on all my Cars and never had this happen
Old 03-19-2018, 04:57 PM   #8
Harry76
Harry76's Avatar
Drives: 2018 ZL1 A10 Nightfall Gray
It is most likely the Electronic slip differential, it can cause it to feel this way as it cycles back and forth.
Harry76 is offline   Reply With Quote
Old 03-19-2018, 05:07 PM   #9
Mcmillion
I have felt that on S/S Mickeys on my C7Z, but that car was a bit twitchy even on the runflats. Was it worse when you put the DR's on? The wheel/tire setup on your car looks great by the way
Old 03-19-2018, 05:18 PM   #10
Tampabucs4
Tampabucs4's Avatar
No it was always kinda squirly and wierd thing is doesn’t do it like 0-60. Only high speed. Maybe I need to turn all the traction stuff off and see if it’s connected to tya
Old 03-19-2018, 05:32 PM   #11
Victoryred1le
Bupp Motorsports
Victoryred1le's Avatar
Drives: 2017 Summit White ZL1 A10
mine does it too. shifts left and right, car makes 680, lowered on BMR springs and oem tires. perfect alignment(checked this multiple times)
2017 ZL1 A10 Summit White LPE LOWER PULLEY, ARH 2" LONG TUBES NO CATS, KATECH CNC TB, BMR LOWERING SPRINGS,STRASSE FORGED MONOBLOCK WHEELS
2016 Mercedes AMG GTS Obsidian Black Carbon interior package RENNTECH R1 kit STAGE 1 TURBO UPGRADE AND FUEL SYSTEM
2018 GMC SIERRA Denali ULTIMATE ONYX BLACK- STOCK AS A ROCK
[/COLOR]
Victoryred1le is offline   Reply With Quote
Old 03-19-2018, 05:33 PM   #12
Tampabucs4
Tampabucs4's Avatar
Very odd right victory. I was wondering if I need to put the canard planer things from 1le in to have it have some downforce in front
Old 03-19-2018, 06:18 PM   #13
init4fun
Drives: 2017 50th Anniversary
You are not the first to mention this feeling running the Mickey's. I noticed this on their old drag radials but those were 275/50/15 on a different car. Same feeling though. At highway speed it felt like the car was swaying back and forth.
init4fun is offline   Reply With Quote
Old 03-19-2018, 06:42 PM   #14
Bill_76
Drives: Camaro ZL1 2018
A10 2018 same feeling....
Bill_76 is offline   Reply With Quote
