#15 | |
![]() Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
I use this as well. Works great. As others have stated, the cooler in the lower section is for transmission fluid that cools the transmission and differential. If you look under the car there is a reverse scoop design. As the vehicle moves forward the "scoop" creates negative pressure under the cooler and the cavity above the cooler is positive pressure. This creates an air current that draws through the cooler. |
#16 | |
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
#17 | |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
