#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Ive had the original set since June. These work great. Didnt track the car this summer so I cant comment on the PDR "noise" but it has removed the darn helicopter inside the cab.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#16 |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
Has anyone sourced which Mic is being used and worked on a solution to relocate or put a Kitty on it? My GoPro doesn't make this buffeting noise but strangely enough my Garmin Catalyst does with the camera mounted on the windshield. I am thinking it needs to relocate to the roll bar.
#17 | |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Shelby GT500 Join Date: Jan 2020
2012 Shelby GT500 with VMP Gen 3R.
Prior: 2023 Camaro 2SS 1LE 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#18 |
![]() Drives: GMC Sierra Join Date: Sep 2024
Ordering a set of the XL now. Do you do any sort of expedited shipping? I have an event this weekend at Barber and would like to try them out.
Thanks! Brian |
#19 | |
![]() Drives: 2019 Camaro SS1LE Join Date: Jun 2025
#20 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
#21 |
![]() Drives: 2022 Camaro ZL1 Join Date: Dec 2021
I just installed a similar product just yesterday on my Porsche Cayman from AWE. Install was simple with detailed instructions.
How hard are these to install?
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2018 Porsche 718 Cayman GTS 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2024 Honda Civic Touring 1971 Datsun 240Z |
#22 | |
![]() There is a small fitment problem I noticed, though: the top of the triangle leaves a gap from the rubber door seal "plate" (first picture), presumably because the OEM part has a twist near the top edge that meshes better into the rubber (second picture) that Wilder Racing's replica doesn't. Feels like a small deal, though, and hopefully won't cause rain damage as the part does have foam padding around the middle section, similar to OEM, just wanted to call this out to give a full picture. I'll try the large "track" variant at some point, too, but to be honest the "standard" one is already good enough for me, and I guess the "track" part provides the same effect to higher speed points rather than suppressing wind noise even further. Installation is trivial, this product uses the same clips as the OEM triangles. Pop the old ones off with a trim tool, press the new ones into the same clip and alignment holes in the door frame, done.
#23 |
![]() Drives: LT1 Join Date: Apr 2024
Just ordered the V1!
#24 |
...and here's what the racing variant looks like from up close. I'm so happy with the "standard" deflectors that I'll keep them on the car, I personally see no need for the last 5% or so the racing version may provide.
#25 |
Ordered a set last night. Got the chemically treated V3 option.
Randy in Nashville
#26 |
![]() Drives: 2016 Camaro SS Join Date: Oct 2025
Ordered the v3 standard finish just now. Spring time is here so window down season is upon us.
2016 Camaro SS A8
Borla ATAK Tuned Drag DR77 Wheels |
#27 |
Installed mine about a week ago. Super simple. Great result and look good.
Randy in Nashville
#28 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
Good up to 156mph in my last track weekend with the v3s. That's a little faster than my normal vmax (151mph) so if it repeats I am gonna say its improving aero with the windows down.
