Old 11-07-2025, 01:34 PM   #1
WilderRacing
WilderRacing's Avatar
Drives: 2019 Camaro SS1LE
Wind Buffeting Finally Fixed – My DIY Solution
Hey everyone,
Like most of you, I got tired of the insane wind buffeting that happens with the windows down at highway speeds. I’ve been experimenting with some A-pillar trim add-ons made from lightweight composite material that totally killed the buffeting on my car.
After a bunch of trial and error, I finally have a version that fits really clean and looks OEM-plus. The difference is night and day—no more pressure pulse or ear-drum popping, even at higher speeds.
If anyone’s been fighting this same issue and wants to see what I came up with, shoot me a PM or check out my build thread—I posted photos and some install notes there. Always happy to share what worked for me and answer questions about materials, mounting, etc.
WilderRacing is offline   Reply With Quote
Old 11-07-2025, 05:15 PM   #2
AZIROC
Drives: '86 IROC-Z '18 ZL1
Which build thread? Id be interested in a pair.
Old 11-07-2025, 06:13 PM   #3
WilderRacing
You can find it here
https://www.camaro6.com/forums/showt...4#post11503634
My website is WilderRacing.com
Old 11-07-2025, 07:26 PM   #4
Ordered a pair of each (original and XL), thank you very much for your work on these I'm excited to see how much they help with wind buffeting, whether the windows are partially or fully down.
Old 11-07-2025, 07:34 PM   #5
AZIROC
Please make a post or (if you dont mind) lmk which of the 2 you liked more. Im very interested. I dont have the PDR but the 1 annoying thing about the car is the wind noise at higher speeds.
Old 11-07-2025, 07:58 PM   #6
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I got the original, smaller deflectors from Wilder (no PDR in my car, so no mics to shield from wind), and they work well. I just did a track weekend at NCM last weekend. I had a passenger for the last session, and we were able to converse pretty well, even at speed.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 11-07-2025, 08:20 PM   #7
WilderRacing
Thank you so much for the support! I’ll have these headed your way tomorrow!
Old 11-07-2025, 08:38 PM   #8
Sounds great, thank you, Sir.
I'll test them and post my experience. Hope the weather will eventually cooperate, given these darn thunderstorms and the incoming arctic blast.
Old 11-07-2025, 09:32 PM   #9
pbSS
Drives: 2023 2SS 1LE
I ordered mine a while back when you posted on the facebook groups. I haven't installed them yet though since my car has been in the shop :o
pbSS is offline   Reply With Quote
Old 11-07-2025, 09:36 PM   #10
AZIROC
Sweet! Looks like I will be ordering a set.
Is XL just for PDR equip cars?
Old 11-08-2025, 06:56 AM   #11
Msquared
Msquared's Avatar
The XL is bigger and quiets buffeting more than the original, and apparently the PDR mic(s) is in a vulnerable spot for wind noise and the XL does an especially better job for it. But you can use the XL version on any 6th-gen Camaro. I stuck with the original "small" version because it looks less intrusive and more like the car came equipped with it from the factory.
Matt Miller
2020 SS 1LE
Old 11-08-2025, 03:27 PM   #12
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
I currently have the Strano deflectors installed. The Strano ones significantly cut down the buffeting, especially at track speeds 90-140mph. But they don't eliminate it.
Does anyone know how effective these are by comparison?
N Camarolina is offline   Reply With Quote
Old 11-08-2025, 03:50 PM   #13
AZIROC
Are those even made anymore? Havent seen much under his 6th gen section for a while
Old 11-08-2025, 05:42 PM   #14
WilderRacing
Strano doesn’t do them anymore for some reason. The other stark difference between the two is Strano’s were more expensive and were a 3m stick on solution. I 3D scanned and reverse engineered the original and these fit like OEM using OEM hardware.
