Old 12-18-2025, 08:14 PM   #15
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by bishopts View Post
Here is a useful one.
If you need a screw to not fall off of your screwdriver. Use a magnet. Take the magnet starting by the handle and slide it down the shaft of the screwdriver all the way off. Now the screwdriver will be magnetic. Its not really strong but it's usually enough to hold the screw.
To remove the effect just turn the magnet 90 degrees and do it again.
The stronger the magnet you use the more effective it will be. Also longer screwdrivers will be more effective.
Same thing works for extensions, knives, wrenches.
Funny story on that one, i magnetized all the butter knives in the drawer to mess with my wife.
Shame on you! and nice tip (pun intended), I think I used to know this and with all the other stuff in there, well I guess there wasn't enuff room! I was wishing I had a magnetic Phillips head recently. And I was certainly happy to see that 'fifty' on my '17's wheel. You don't have to get a 50th Edition for a little reminder of the car's history.
Keep the FYI's coming guys and thanks for the trivial pursuit answers in advance too!
Ventmaster is offline   Reply With Quote
Old 12-19-2025, 01:13 AM   #16
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
One thing I've done quite a bit when I'm taking out a screw I really don't want to fall and have to retrieve: Stick a magnet to the side of a screwdriver and the magnetic pull will work through the screwdriver to hold onto the screw
speedyink1 is offline   Reply With Quote
Old 12-19-2025, 07:40 AM   #17
ef_in_fla
ef_in_fla's Avatar
Drives: Camaro 2LT RS 2017
It looks like you removed that rubbery coating on your steering wheel by the Fifty deal. Is this on purpose or did it just wear off? Mine is showing some wear.
2017 Camaro RS
ef_in_fla is offline   Reply With Quote
Old 12-19-2025, 08:51 AM   #18
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
It was like that when i got it. I thought it was normal
Old 12-19-2025, 03:24 PM   #19
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
They’re notorious for peeling, it’s flat/matte black originally then semi-gloss after it’s peeled. Happened to both of my cars, you can get replacements but eventually they’ll all peel
2016 1LT v6
- Totaled
Happiness: Infinite
Old 01-07-2026, 03:51 PM   #20
bishopts
bishopts's Avatar
Here is one most people dont realize, the tread lugs on tires are different sizes than the ones next to them. If you look at your tires you will see it. Some are shorter or longer than the one it came before so that it reduces tire noise. I actually learned that one in a NHV class when i worked for dodge.
