Old 07-01-2025, 10:29 AM   #1
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Did you know?
Did you guys know the painted dot on the lip of a can tells you what side the straw sits on inside the can?
Old 07-01-2025, 01:31 PM   #2
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Finally. I've always pointed the nozzle at the dot, but never bothered to find out why
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune l GM Lowering Kit
Ported LT2 Intake Manifold l Ported 95mm LT5 TB l BMR Rear Cradle Lockout Kit
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l 480whp/467wtq
SSShark is offline   Reply With Quote
Old 07-01-2025, 01:51 PM   #3
bishopts
bishopts's Avatar
Lol yea. If you're spraying down then point the nozzle to the dot. If you're under the car spraying up, point it away from the dot.
Old 07-01-2025, 01:59 PM   #4
SSShark
SSShark's Avatar
Ha, never knew that either. Thanks man
Old 12-08-2025, 10:43 PM   #5
bishopts
bishopts's Avatar
Found out that i can turn on defrost, vent, and floor all at the same time
Old 12-08-2025, 11:03 PM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
LOL- so how is the weather down in Dallas today? not good?
And +1 for "didn't know that until today"! Thank you, sir! It all adds up, this knowledge base we pass on to younger generations as they think "so what?".
Actually, I have a granddaughter that will see the value in that info. You never know enuff or too much.
Ventmaster is offline   Reply With Quote
Old 12-08-2025, 11:08 PM   #7
Yep, we can blast air on all "cylinders"
Old 12-09-2025, 04:28 PM   #8
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
I did not know this part either, thanks for the tip!
My Camaro Journal
Old 12-09-2025, 04:29 PM   #9
DamonZ28
DamonZ28's Avatar
Not sure that I've ever had a need for it, but good to know just the same!
My Camaro Journal
Old 12-11-2025, 02:01 PM   #10
bishopts
bishopts's Avatar
This is one that i didn't know until i got my car. All 2017 camaros had this steering wheel plate
Old 12-18-2025, 12:10 PM   #11
bishopts
bishopts's Avatar
Here is a useful one.
If you need a screw to not fall off of your screwdriver. Use a magnet. Take the magnet starting by the handle and slide it down the shaft of the screwdriver all the way off. Now the screwdriver will be magnetic. Its not really strong but it's usually enough to hold the screw.
To remove the effect just turn the magnet 90 degrees and do it again.
The stronger the magnet you use the more effective it will be. Also longer screwdrivers will be more effective.
Same thing works for extensions, knives, wrenches.
Funny story on that one, i magnetized all the butter knives in the drawer to mess with my wife.
Old 12-18-2025, 03:47 PM   #12
If you're tired of the faded and frayed edges, that nice F1FTY center badge can be swapped onto a new plate. You could even go aftermarket and get a carbon fiber one, then swap the badge over.
Here's what I did for my 2018 that came with a simple red SS emblem and I wanted something more unique.
Old 12-18-2025, 03:55 PM   #13
bishopts
bishopts's Avatar
I'm actually still considering the steering wheel you suggested a while back. But i need to change my wheels and tires first.
Old 12-18-2025, 04:03 PM   #14
Cool I still absolutely love that steering wheel, the girth is just perfect and the whole contraption doesn't look half bad either.
