Old 06-24-2025, 11:15 PM   #15
Og Neon
Lover of Speed
Drives: 2018 ZLE
I've been running Motul 600 for over a decade and I do about 15+ track days a year with no issues. I usually flush at the start of the year and bleed midway and maybe at the end depending on the tracks.
Don't let them scare you off, Motul is just fine. Regardless of the fluid, if you have bad braking habits, then any fluid will boil. I see a lot of new track guys getting on the brakes way early and riding them thru the braking zone which starts to overheat things. Additionally, PTM will heat up the rears a lot if you are ham fisting it and it is constantly engaging.
Killer Whale Racing
2021 One Lap of America Track Videos
2019 One Lap of America Track Videos
2017 One Lap of America Track Videos
2022 Ram TRX
2018 Camaro ZL1 1LE
2020 Range Rover Sport SVR (Sold)
2014 Grand Cherokee SRT (Sold)
2014 Camaro Z/28 (Sold)
Og Neon is offline   Reply With Quote
Old 06-24-2025, 11:48 PM   #16
Skyman2112
Skyman2112's Avatar
Drives: 2016 2SS blue velvet w/blk stripes
Smile
Originally Posted by 5.M0NSTER View Post
Castrol SRF ftw. I change every 2 years, and do 8-10 track days on a flush. I also drive my car 5-6 months a year as a daily
Wow thats great ill check it out!
Current mods. Rotofab CAI, Speed Engineering Long Tube Headers and plug wires w custom tune. Shock tower brace, ground effects, OEM brake air ducts and splash gaurd delete, 275/315 tires on 10 and 11 inch MRR wheels.
Skyman2112 is offline   Reply With Quote
Old 06-25-2025, 01:18 AM   #17
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Motul RBF 600 is the best in terms of highest boiling point if fluid is free of water or fresh.
Castrol SRF is close, but both are high tier.
I personally use a "mid" tier for a lot less money and fairly high boiling point of >500°F.
Just fine as well on track, even with frequent high speed braking. 160+ mph -> 25.
The stock pads overheat way before you are able to cook the brake fluid.
Most importantly is to keep it fresh, so 1-2 changes each year. (depending on use and weather)
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 06-25-2025, 09:02 AM   #18
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
If you don’t want to bleed before every event or during the season I’d just switch to castrol. I had the same thing happen to me that poster number 5 had happen however I’ve learned not to do a cool down lap. It literally gets firm again by the next corner. Still, I don’t like that the pedal gets momentarily soft so I am switching to endless rbf650. I think that’s also a fluid that doesn’t require changing that often. Motul requires bleeding during the season.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 06-25-2025, 09:28 AM   #19
USMUCL
Drives: 2021 Camaro 1SS 1LE
Probably worth noting I was on Sport 1 when this occurred; in theory, the computer was using the brakes for stability and it contributed to the hot fluid. When it happened, it also turned my pretty red calipers black.
I have since progressed down the list to RACE
USMUCL is offline   Reply With Quote
Old 06-25-2025, 09:33 AM   #20
m6-lt1
m6-lt1's Avatar
I was in sport 1 as well but my calipers are still red. Looks like we had two different things happen then and you definitely needed to do the cool down. I think in my case the fluid was just getting more compressible as it was getting hotter which I was reading happens more with castrol versus endless. One of the posters in this thread had told me that about castrol as well.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
boiling point, brake fluid, track day
